ian1964
Everything posted by ian1964
  1. As usual nothing in life is simple, Indicators are not a standard yam fitment, Fowlers did mail me a wiring diagram for the upgraded 250f with indicators and the relay was about £82.00 which is a bit much for trial and error, the relay above is mounted near the headlight, the Yamaha fitted one's are near the battery on the wiring diagram , I have looked everywhere and there are no manufacture markings on the relay or the indicators just though would post here with the chance that somebody may know what make they are , as I'm struggling to find a replacement relay Many Thanks ian
  2. Brill, Thanks you , just emailed Fowlers Thanks for your help Ian
  3. HI All Can anybody point me in the direction as to where the indicator relay is mounted on a 2018 WR250F , many Thanks Ian
  4. Just a quick update, done 1300 miles on the bike since fitting the coil and its all ok so far Many thanks to all who replied and helped Regards ian
  5. Thanks for you're replies Cynic , yes I checked the Secondary side (coil to spark plug cap) was 11.5 , and plug cap to cap which was 9.46 all within the limits , there is no ignition switch but I will check the earths I guess there is more than one. I have had the bike for 6 months now and have put on just over a thousand miles with no problems , first time it happened the bike started and seamed ok after leaving it for about 15/20 minutes, the second time the bike had cooled down and stopped just after I had set off. I tracked a site down that said the 3 short flashes and 3 long flashes on the engine warning light pointed to error code 33 which is ignition coil (faulty ignition ) Have ordered a coil and hoping this is the problem, however may be wrong as its a bit strange that its only done it twice and bike had done a further 100 miles before it stopped again. Regards Ian
  6. Many thanks for the reply's appreciate it Have removed coil and tested, Primary Resistance is a small amount out at 2.7 (Yama manual says 2.16 to 2.64) however this is measured when its cold, and as Finnerz said I have only had problems when the engine is hot Secondary resistance and plug cap all checked out ok, I have gone ahead and ordered a new coil, hopefuly this will fix the problem, will report back. (coil on a 15 day delivery time ) Regards Ian
  7. HI All Looking for a bit of help, recently bought a bike after not been on one for 40 years, its a Yamaha WR250F 2018 model, which has run great until now, last week I was out and it missed and spluttered and finally stopped and would not start, after leaving it for about 15 minutes all was well and it got me home, changed the plug which looked ok, done a few more rides out and all ok, so I thought maybe I had some dirty fuel. anyway went out today and it just cut out, engine warning light was flashing 3 long followed by 3 short flashes ,it did start after leaving it for a bout 30 mins, just looking for any help at what the problem may be Many Thanks Ian
