Everything posted by Snakebite68
Dodgy swingarm...
Hmmm, I'll look at that...
Dodgy swingarm...
Yeah, I know it's not a hard job, but it's my ONLY mode of transport, so if I get stuck, I can't get to work! lol I've solved that problem by buying a V-Strom (well, I'll be buying it today), this means I can just take my time with the Ace and do it properly. I just have to figure out a way to suspend it from the garage rafters since I don't have a centre lift! lol
YZF600 Thundercat Intermittent Starting
It could also be the same problem but with the main kill switch...
Dodgy swingarm...
Bugger... Thanks anyway lol
Dodgy swingarm...
So, my Thunderaces swingarm is starting to seize up (frankly, I was constantly thinking it was my rear tyre that was soft! lol). I would like to do the work myself, but I'm skeered! 😰 I'm off work for a week, is there anyone in the Wakefield area that would like to come over and crawl around a hard garage floor with me to kinda give pointers and second guess me? There could well be bacon sandwiches and unlimited cups of tea in it..! Basically, since I've never removed a swingarm before, I just don't want to do it on my own in case I get into trouble and can't carry on... 🥺
M.A.G. Membership changes...
So, as I may (or may not) have said, I've just moved house... I went to the MAG website to change my details but couldn't find either a 'login' option or an 'account' option. Am I missing something obvious or is the only way to change your personal details with them is to phone them?
Yamaha G6/G6SB/G7 mystery bearing!
You should enrichen it with a new air filter by the sound of it!!! lol
Yamaha dt 250mx wheels
No actually, when I'm looking for parts, I tend to use that type of site just for reference purposes and to grab the part codes. The fact that you can check other bikes that use that particular part is an extra! Oh, and don't call me Shirley!!!
I think you missed a letter... https://www.cmsnl.com/ Looks like an interesting website! Cheers!
That's pretty cool!
Battery charging issue - new biker looking for help
P.S. Four LONG flashes, three SHORT flashes? Fault Code 43 Fuel system voltage (monitoring voltage) The ECU is unable to monitor the battery voltage (an open or short circuit in the line to the ECU).
First question is: WHEN exactly did you buy it? Second question is: Was it private or dealership? If you've literally just bought this bike, then it's not your problem (unless you knowingly bought it with electrical problems). If it doesn't get you around, then it is 'unfit for purpose' and a FULL refund is warranted... There are MANY more bikes out there to chose from, there's no reason to take on a problem when you don't need to.
aftermarket silencers
Armour appear to be more about classic bikes rather than performance bikes. But they do look nice.
Not a Yamaha, but
Mmmmm... Shiny bits...
Who knows... lol But I'm looking at these and drooling! Blueflame-performance-motorcycle-exhaust-and-systems (blueflameperformance.com) And for the whole deal... YZF1000 R Thunderace 1996-2003 Exhaust Downpipes Headers (blackwidowexhausts.co.uk)
Bike Registration
The first thing I'd want to know is whether the NI one with no V5 is stolen or not... You might want to check the VIN.
Yamaha 2005 XT125R front brake not holding pressure. Please help!
Woah, woah, woah, woah..! Chances are that if you had a cracked calliper, you'd know about it! It sounds to me like your bleed nipple is blocked. It's fairly normal for air/fluid to come out of the threads... 1/ Don't crack it open quite as far, it's only supposed to be cracked enough to let air out then nipped up again quick. 2/ Buy a new bleed nipple (I'm pretty sure they all have the same threads on them...). Out of curiosity, how are you bleeding the brakes? Are you: a/ Doing it the old fashioned way and using the lever? b/ Using a vacuum bleeder? c/ Using a pressure bleeder?
Keep looking! Yamaha XT 125x Xt125r Genuine Master Cylinder Front New Ajp High Quality Oem (ebay.co.uk) E-Bay is your friend!
WR125X Error code 33
What exactly is the fault code you're seeing?
plug cap prices
Aaah! Yes, but the rain is warmer down there, you should try it up here in Gods Country!
plug cap prices
Still doesn't explain the nearly 2mm gap on the old plugs! lol Bike works! Get out there (this is what rain gear is for)!
plug cap prices
Those sound right offhand. So I've heard, I've not done it yet lol. Stupid question, you did check the gaps on the new plugs before you put them in, didn't you?
plug cap prices
The Thunderace will take two different plugs (they're listed in the manual). If you don't have a Haynes Manual, say so, I'll dig mine out...
Coughs and splitters at 5000rpm
YAMAHA YZF750R EXUP SERVO MOTOR WITH BRACKET EXHAUST ENGINE YZF750 | eBay 2 seconds on google...
My poor bike is suffering...
Well, the red grease SHOULD be there anyway. That's what the pistons should be greased with anyway. The brake callipers aren't a problem for me, I bought a second set, so I can just swap them out when they need maintenance and do them at my leisure...
