Everything posted by Snakebite68
Yamaha XVS 650 part identification?
Google is your friend... All I googled was "XV 650 spares" Then just pick one of the sites that show exploded diagrams of your bike. Once I knew it was part of the frame, it was easy...
Yamaha XVS650 DRAGSTAR 2002 Frame - MSP (motorcyclespareparts.eu)
What year, what country?
Hello all from Northern Ireland
Couple of Sundays and it'll be fine...
Newer 1978 DT175E owner (Colorado USA)
Welcome in...
Yamaha r1 2008
At the point where it doesn't start, can you bump start it?
Which oil
Try Yamalube 10W40 Semi-Synthetic... Fully Synthetic isn't a good choice for the older bikes.
LED bulbs for 2001 XVS650 Classic
Oh, and contrary to popular belief, you can't just stick an LED bulb into a incandescent/halogen light (even though they DO make LEDs to fit), because an LED bulb requires a different shaped mirror...
Not done it, but obviously you need drivers for them too. I'd personally look out for kits. But the first thing you need to know is: Is your bike CANbus (Controller Area Network bus)? If it is, you're in for a world of confusion! lol
Yamaha r1 2008
The problem may be that we get a lot of people coming in, asking one question, then never replying again. Might be an idea to go make a post in the 'New Members' area, introducing yourself & so on... It may be that we need more sentences and punctuation (my favourite), long single sentence rambles often confuse people! Or, it's possible no one has a clue (most likely)... Have you got any more information? It's pretty thin on the ground at the moment. Does the engine make any 'pinging' noises when you turn it off? Is it running at a steady temperature? Is there plenty of liquid in the radiator? In the 30mins or so that it won't start, does it turn over as normal? Or is there nothing happening?
Yamaha xvs650 Dragstar Classic 2001
Looking good...
Yz125 2003 transmission bearing
Yamaha 93306-30411 BEARING (fowlersparts.co.uk) £24 Yamaha 93306-30411-00 - BEARING (B6304) | Partzilla.com $29.97 Yambits : 93306-30411 for Yamaha bikes £13.99 That's just from a quick google search of the part number... Google is your friend (so is Yambits!).
Yamaha r1 2008
Looks like you posted this 3 times...
Ticking from engine
Duplicate post?
Do you have the exact item code?
Exhaust studs
I want to swap my exhaust studs for titanium, but there's not a chance I'm going to attempt to take out 20 year old studs myself! lol
Hello from Brisbane, Australia
Check to see whether the baffle is still in your exhaust.
Exhaust studs
Take it to a mechanic. If you're not geared to deal with a snapped stud, let a professional deal with it. You're only ever one snapped bolt away from fucked with home mechanics..!
Battery connected in reverse
After the above, and solving the problem, put an in-line fuse in the negative terminal (I've found it saves a lot of problems for all sorts of electronics!)...
Dodgy swingarm...
There's always that problem lol. Mine will require aluminium welding on the gas can (IF it can be welded), I've bought the best one off E-Bay, if it turns out to be duff, I'm hoping the can is in better condition, so I can make one out of two... If it turns out to be in good condition, I'll get mine serviced and then I'll have a spare!
YOC Meet 22
Well, that sucks...
Dodgy swingarm...
I took the shock off today (strangely, almost as difficult a job as removing the swingarm!!!), the shock is definitely not a sealed unit, so I'm looking good there. However, it's one of those shocks with the remote gas canister (attached with a pipe), and it looks like there may be some corrosion damage to it, so it may be borked! We'll see how it goes...
Hello from South Africa
Hi there Heino, good luck with your project, and... We like photos!
Dodgy swingarm...
Just as an update, this is done... I took it to work and suspended it from a forklift in the shop just before Christmas! I was right to be worried, it turned into a bit of a pig of a job. The bearings were trashed in the suspension rocker (not something I knew I should be keeping an eye on.), once out, it turned out that I had a faulty rocker anyway, the central hole necks down in the middle, and mine was cast off centre!!! It wasn't by much, but it put pressure on the bearings, which is probably what trashed them in the first place. E-Bay and motorcycle breakers solved that problem with a new rocker that frankly looked almost brand new with perfect bearings still in it! Unfortunately, once all back together, it turned out that my rear shock has failed..! So, as a bonus question: Would I be better off: a/ Getting mine reconditioned (assuming it's possible)? b/ Getting a replacement from E-Bay? c/ Buying an aftermarket shock? I'm currently leaning towards 'b' AND then later 'a', which will give me a spare... Thoughts? P.S. WOW!!! EIGHT months later! I like the V-Strom, but man, I miss my Thunderace, this needs sorting out soon for the good weather! lol I think I'm gonna run the V-Strom over winters and the Ace for the nice months from now on...
Charging problem 2002 Yamaha xvs650 dragstar
The obvious answer would be a duff battery. But you'll want to check for shorts too... P.S. Check the main earth.
