Snakebite68
Everything posted by Snakebite68
  1. Snakebite68 replied to Livests's topic in Mechanical
    Well, that's not good, I'm assuming the engine hasn't ingested it? All I know about the Thunderace Carbs is that the emulsion tube isn't replaceable... NOT that I know what an emulsion tube is...
  2. Snakebite68 replied to John1's topic in Mechanical
    It's like the heaviest timing chain ever! lol
  3. Snakebite68 replied to John1's topic in The Bar
    Wemoto are good, and if you're having problems, they're very hapy to take phone calls. P.S. Recommendation...
  4. Snakebite68 replied to jcr's topic in The Bar
    I saw those, but it says they're for threaded terminals, I'm pretty sure the Ace doesn't use threaded plugs.
  5. Damnit..!
  6. Snakebite68 replied to Livests's topic in Mechanical
    I have no idea about carbs, what are we looking at?
  7. Snakebite68 replied to jcr's topic in The Bar
    I too am a little shocked, spark plug caps are not something I've had problems with on my Thunderace so far. You may have to bite the bullet, after a cursory search, this is all I've found..: YAMAHA YZF 1000 THUNDERACE 4SV 96-03 - IGNITION COIL CAP PLUG CAP - ONLY 3 | eBay
  8. Wait, are you me?
  9. Snakebite68 replied to John1's topic in Mechanical
    Looking good so far... That's a hell of a chain in there!
  10. Snakebite68 replied to Livests's topic in Mechanical
    Exactly, all that fuel you're pumping has to go somewhere...
  11. Been there... Done that...
  12. The Shetlands huh? That's going to be a lot of 'round and round'..!
  13. Yeah... 40V doesn't sound right at all! I have no idea how to fix the problem or even what the problem is, but you could always try to suck up some of that power by slapping a load of xenon headlamps on the front like a 1970s Mod Lambretta..! 🛵 Other than that, I'm sure someone else will have a better idea!
  14. Nice, clean, simple chop. Old school, I like it!
  15. Even if the battery died, wouldn't it continue to run on the alternator?
  16. I've got an ART can on the 'Ace currently! 😀 The answer is definitely the pipes. And getting rid of those original headers will only help your power to weight... Just make sure that you have the same clearance to your fairings. Paying out for a good quality pipe will make all the difference.
  17. Carbs are magic items beyond the ken of myself... But I'm sure there's plenty of others in here that know about them lol
  18. My first thought would be heat ceasing... Does it actually turn over? If not, check to see whether it starts as soon as it has gone cold (rather than overnight).
  19. Have you got a full exhaust? Or have you just removed the valve and connected the two halves? If you're still using your original exhaust, it's designed to work with the valve. You're gonna have to get an aftermarket exhaust and probably a can too. Modern exhaust systems are designed to give a good response over the entire rev range, the exup was apparently a fix for lesser technology... I've been drooling over this for my Thunderace: YZF1000 R Thunderace 1996-2003 Exhaust Downpipes Headers (blackwidowexhausts.co.uk) I'm sure if you gave them a ring they could do something for the 750. And these cans look good too: Blueflame-performance-motorcycle-exhaust-and-systems
  20. Check out this link for a visual on what Cynic is saying... Plug Colour Chart
  21. NICE animation!
  22. You're certain it's not your gearbox?
  23. Fault code 19 - No signal from ignition to ecu Have you checked the kickstand kill switch?
