mikso
  1. Hello everybody! I have a Yamaha X-max 125 (2010). The problem is I can't start it up. Maybe you could give me some ideas what to do? So, the symptoms are that the starter works but there is no spark. I also noticed that when I turn the key to ON state, I can't hear the fuel pump as I used to. Also the immobiliser diode doesn't light up at all. Can you give me some hint what I could do to diagnose this problem further? Could that be a failing immo? Maybe some water got into it? Or rather is it the ECU? Or maybe (hopefully) there is something else I could check/fix?
