Steve kerr
  1. Hi guys, wondering if you can help me. I’ve bought a innovv k2 front and rear camera kit. Fitted it all good except the ignition live. ive fitted it to my headlight which is on when the bike is running and not(discovered afterwards) just on ignition (not running)1click. apparently it should just work without touching it once the ignition source is fed to the system. Mine doesn’t even when the bike is running without manually taking off the seat then pushing the on button. Obviously this isn’t the way to go. My theory is(correct me if I am wrong) is it wouldn’t matter when the ignition source is powered, 1 on ignition or 2 on startup the “power on” should kick in whatever stage the unit is live. Yes I could strip it all down and feed it to an ignition live source but I ain’t sure that’s when the issue is. It’s the box not the power source? anyone with any help or tips on this would be amazing as I am at my wits end. Thanks for reading. regards steve
