If you can sing the praises of XS360's, Let me hear your song!
It is a XS3602D. The main difference is it doesn't have a starter, kick start only. Drum breaks front and rear may be a diff too. But I think everything else is the same comparing part numbers and etc. A good place that I've bought parts for mine is partswarehouse.com. You can look up all the parts available similar to micro fiche. Let me know if you can't find the site and I'll get it to you. Best of luck....Harv.
Heck No !!!
I bought mine on e bay
Yes, fork seals. Mine leaked slightly when I bought the bike and I got good help-info from drewpy on most of my repairs.. He is Da Man !!..
I added an original luggage rack and engine guard since last pic's.
Boy, this is a bummer... I can't get your pictures !!. It states that Im not allowed access to your pictures We'll have to figure out a way to get the pics of your super bike on the forum.. Once you have registered on photo bucket, import the photos from the other source in to photo bucket. On the picture you want to post here, left click the bottom option below the picture"IMG Code", it will hi lite, then right clik and select "copy". Then go to this forum to where you want to post the picture , left clik to set the place for the photo. Right clik and select "paste". I hope this works g-man. If not, we'll get some help here on the forum.. Best of luck....
I have my pictures in Photobucket. I select the picture I want to send, Left click the bottom option : IMG code, then right click "copy". Then go to the site you want to post the picture on, then right click "paste". There are probably better methods, but I'm not much of a computer whiz... Best regards.... Harv..
Mike76,, Keep it !! It is a fun classic bike.. I bought mine two years ago and it has been all fun plus a lot of learning and help from this forum. Drewpy gets the Gold Star for being the Exalted Guru and Grand Pubah as far as I'm concerned on these XS's. I did the fair wear and tear fix up on it after I bought it, fork seals, Ignition coils and condenser , had the carbs cleaned etc. Here is a picture of my Whizbang :
Clutch problem XS360
That did it Drewpy,, Thanks again..
I looked thru the search options and didn't find my answer. Problem is I can not engage the clutch . Start it in nuetral with clutch handle pulled in, Put in 1st, kills the engine . Naturally I tried the cable adjust with no luck. For the clutch adjustment, the book says loosen the lock nut and etc. I can't loosen the lock nut because it feels spring loaded . I hesitate to force the nut too much against the spring resistance thinking I'll hear a loud BOING and then have bigger problems. ??????
Avatar
- Avatar
Well, I thought I posted this but I guess it got lost. I attemted to add an avatar by going to My Photobucket "Copy" the picture, went to My Controls, Edit Avatar and "Paste" in the area for the picture. It didn't work so I'm missing something and being fuzzy headed doesn't help.. Thanks for your help..- Engine polish
I have the old laquer-shellac ? coating removed from the engine and buffed it up. I looked back in the forums trying to find the posts on what some of you prefer as a polish on the engine after it is nice and shiny. Couldn't find them. Appreciate your help.. Thanks..- xs360 stumble?
Hello Joe4,, You might try www.metricpartsdirect.com They were previously Yamaha Parts Direct, but Yamaha didn't like that so they changed their handle. They have a very good parts listing for the XS360. I had bought several items from them trying to get my XS3602D back to original. Thanks to all the great people on this forum !!.. Hope this helps..Harv.. p.s. postage is a bummer nowdays..- XS360 Carb. joints
Yes,, I put a post in here some where awhile back. The Carb. joints for the XS400 fit my XS360 perfectly. Different part numbers,, so the part numbers can be misleading.. I got mine on E Bay.. Thumbs up !!! - Avatar
Harv
Joined
Last visited
