deegee753
  1. Hi, Up until now, when I turned on the ignition switch of my FZS1000, before starting the engine, both the dipped main beams came on. But now both the side lights come on and the dipped or main beams can not be turned on via the head light switch. However the main beam comes on using the head light flasher switch. The lighting fuse is good. Have I inadvertently somehow changed the option for side lights on power-up instead of dipped main, if there is such an option, but I see no reference to this in the manuals? But the main beam should come on via the head light switch. Or perhaps a problem with the head light switch? Cheers
