Ads00
  1. Ads00 posted a topic in General
    Hi I have a 2007 model and I have trouble with false neutrals alot. Is it possible to let me know why this could be happening.
  2. Ads00 posted a topic in General
    Hi I have a error code 19 (no signal from ignition to ecu) on dashboard. I have replaced the ignition switch as old one was faulty. Previous to this I had a error code of 46(power supply to FI system) which I had to change - Blocked fuel injector ECU unit Stator Magneto (burnt) Replaced Battery as old one was not holding charge Checked black/white wire traced from ignition to ecu which is fine on continunity I have no spark so waiting for a replacement ht coil to see if this is the problem. I have changed the ht coil still not working. Can anybody let me know if could be wiring loom a break somewhere?
