jonasmx
  1. Here the problem now is the speedometer, why it did stop working? who knows and maybe it was a coincidence non related with what I did. Right now my bike is on the shop getting some adjustments, fixing the water pump problem and two more things, once I got the water pump fixed then I will wire the fan to the thermostat and see if it is eventually activated by thermostat. I am not expert but I don't think I shorted circuit the wrong cables, they were coming off from the radiator part, just like my old SV650, but who knows I am still confused about this. Please note that the FAN is perfect condition, it runs good once directly powered from the 12v source.
  2. Hi, im new here. I have a question, I recently got a yamaha fz1 2005. I jumped the thermostat radiator cables in order to have the fan always on, I did the same on a sv650 2000, but this time did not get the expected result, after that, no more rpm reading, the needle was dead. I after discovered that the problem was the water pump, so maybe the thermostat was ok. I did not get the fan on, why? I removed the jump and ended wiring the fan just directly to the battery, using a switch, after that the electrics seems ok, just the speedometer that won't turn on. Does anybody know what exactly happened? I checked the fuses and seemed ok. thanks.
