Renfield
  1. I keep checking the official Yamaha accessories page for risers for this exact reason. I'm also 6'1" and the stockers definitely force me into a more agressive forward stance. It would be helpful to find a stealer with those bars in stock. I don't like to buy blind. All they carry locally are the bikes. I will check price at yamahasportscenter.com. Tony O is hard to beat. Thanks for the info on the bars and the alternate forum. This bike deserves it's own topic area.
  2. I've always avoided the crash bars, as I tend to drag the floorboards in curves. Additional lighting would be my choice. You can't be too visible for the distracted cagers. Where have you seen risers? That might add some greater level of comfort.
  3. Looks sharp. What's next?
  4. You're on the customize till you drop crusade. LOL. Good luck. Can't wait to see. I'm thrilled with my stock tourer. 6K+ miles of smiles. I'll replace stuff when (if) it breaks. Right now a new rear tire is high on my list. Bridgestones aren't holding up very well. Cheers, Renfield
  5. Renfield replied to tejas 1300 star's topic in The Bar
    I see you now have a 1300 Tourer. Congrats. Was there some reason you decided to go aftermarket for the touring upgrades?
  6. Renfield replied to david1950's topic in The Bar
    My take (value: approximately two cents) is that lugging the engine is worse. This bike will shake your fillings loose at the shift points Yamaha recommends. I don't get into 5th gear until about 45-50 INDICATED mph. A bike that comes with no tach cannot be overrevved. Haven't hit it yet, but I expect it's got a rev limiter just like the smaller/cheaper siblings (650 classic). Noises? Yes it makes noises. Most are pretty sweet. I'm past 5K miles and two service intervals. Clutch noise is as it was on day one, just as described by ZenCruiser. Anyone finding a good price on a replacement air filter yet? Cheers, Renfield
  7. Renfield replied to david1950's topic in The Bar
    They fit my old 650 just fine, and the brackets I made for them would likely work great on the 1300. They're a universal design, and I attached them to the bolts that you'll be using for the backrest. I can send you some photos if you send an email address. Mine is: [email protected]. I bought the bags from cruiser customizing (I think) and used the stock Yammie saddlebag mounts with my own bolts and standoffs so that they were hard mounted. I also added twist lock closures so the velcro wouldn't release at highway speeds. Not sure if the 650 bag mounts will fit the 1300, but I still have those lying around too.
  8. Renfield replied to david1950's topic in The Bar
    Definitely a better deal to buy the tour model, if you know you want those accessories. I learned my lesson the hard way with my vstar650. I have a set of saddlemen jumbo slant bags if you're interested. I got lucky and found a set of Yammie hard bags for $350 on ebay for the old bike. Won't make the mistake again of buying without the accessories.
  9. Renfield replied to david1950's topic in The Bar
    While we're wishing, I wish the Yamaha Owners Club had a dedicated forum for the V Star 1300. This post is running long and going all over the place, topic wise. Good luck with your new backrest! Cheers, Ren.
  10. FWIW, $35 seems like a steal for that gauge package. I paid about $55 for an electronic version that I've used for several years. Hookup is simple, calibration is quick and precise. Worked with my carburated Vstar 650, and still works with throttle bodies on the fuel injected 1300. I'm no mechanical genius, so listening to the pipes or reading the tea leaves is not an option for me. Props to those of you with such skills. I consider the sync tool an excellent investment that eliminates guesswork beyond my capabilities, and keeps my ride running smoothly. I can tune my guitar and bass by ear, but I use a $50 stage tuner for that task as well. Hey, it's fast, simple and very precise. So shoot me. Good luck! Renfield
  11. Thanks for the award nomination, I guess. Too often stupid and gutsy are interchangeable. Anyhow no guts, no glory right? I performed the second valve job last Sunday at 4,500 miles. Took roughly half as long as the first effort. Only removed seat, tank, plastichrome covers, plugs, and of course the engine trim panel that reveals the timing marks. Didn't even remove the aircleaner, but I did take off the throttle cables at the throttle body. It helps having a sawed off 5mm hex wrench when removing the valve cover on the front jug intake (the one under the coolant hose). All in all, a bit cramped but perfectly doable. With a minimum of hassle compared to the shop manual prescribed method. Even with twice the valve count, it was an easier job than on my old 650 Classic. And your scrap wood idea worked well for reconnecting the vent hoses under tank. Throttle body sync was still spot on - no adjustment necessary. Cheers, Renfield
  12. Renfield replied to david1950's topic in The Bar
    Cobra makes one for the 1300 that costs $225 from cruisercustomizing.com. Haven't seen it in person. Here's a link I love the one that came on my tourer. The factory passenger backrest components cost $354 from yamahasportscenter.com - cheapest I've seen. Which probably explains why you've gotten no response to either post. There's a company called bakupusa.com offering a nice backrest for the driver. Too dear for my wallet at $350 plus shipping. Makes the Kuryakyn backrest bag an obvious choice for the 1300T driver at about $145. That's what I'll be getting for long trips, as it adds useable storage space and a driver backrest for much le$$. Alas, no help if you have no passenger backrest. Maybe prices will drop if and when the 1300 becomes more popular. For now, the limited selection of Yamaha accessories seem steeply priced compared to other models. Fortunately, the tourer came with all I need. And the extra cost was less than adding the factory hard bags. Easy decision. Cheers, Renfield
  13. Renfield replied to david1950's topic in The Bar
    I've checked my speedo against two radar speed displays set up permanently on either end of the main drag through a new local neighborhood/golf course. They like to walk their dogs, jog and drive golf carts down the middle of this main street, even though there are no homes or driveways on it. so they're quite adamant about pointing out the speed limit. At an indicated 40 mph, the radar reads 35. At an indicated 60 mph radar reads 55. The error seems more linear than a set percentage would return, but seems consistent with your experience. Makes me wonder if Yamaha has considered this when offering shift point advice in the owners manual. If I follow their guide, it always seems like the engine is lugging. -Renfield
  14. I did the 600 mile valve service about 2800 miles ago. Did NOT remove hoses OR throttle bodies. Never opened the radiator. A long screwdriver will pry the top hose aside just enough to access the valves. It was still a very lengthy process, and one of the most difficult parts was reattaching the forward vent hoses under the tank. It took another set of hands for me to accomplish that feat without scratching anything. I hope round two will go more quickly. It's coming up soon. Good luck. Renfield.
  15. Renfield replied to david1950's topic in The Bar
    The only whine I've noticed is from my wife. When the divorce is final, I expect that to go away. (Sorry. Couldn't resist. ) My clutch was not adjusted properly at the dealership. Might be worth a check. Everything got considerably quieter when I did the first oil change to synthetic. Passed 2000 miles now with no troubles. Bags get a bit wrinkly in the rain, despite all the mink oil treatments. Maybe they skinned an old Kaw? Cheers, Renfield
