Hi,
I have DT125 (03) with a leaking rear shock. I have purchased a replacment part but was wondering easy it is to fit. It apprears to me that its just 2 bolts, one each end, Is it really that easy.
Any advice would be much appreciated, even if its take it to a garage!
Thanks,
Andy
Hi,
I've recently purchased a DT125R (2 stroke) 2003 and have a couple of questions that i need some help with.
1. There is an oil filler cap by the kickstart and a viewing glass below it. It would appear as there is a line on the engine case next to the glass that it is need of some oil as there is none visable. Can anyone please tell which oil is recommended and if this line is a maximum or minimum.
2. The bike seems to run okay, it was a little rough initally as it had been stood for 12 months. I've let the tank get almost empty and put fresh petrol in, however the bike runs fine up until 7-8K Revs and then seems to loose perofrmance (Still runs but will struggle to go any higher) Is this typical of this bike it is standard and has not been de-restircted. My first thought is the power valve is not operating but you can hear it turn when you first switch the ignition on.
Thanks, Andy
