jaanimardikas
Everything posted by jaanimardikas
  1. Hi, I have an oldrunner Yamaha XJ600 (build year 1989) 51J. I wonder if there is anyone who can pinpoint my problem. While riding all the lights (including the dash) become bright for a few seconds and then return to normal and sometimes they dim below normal level too. It fluctuates all the time but especially when at higher rmp. Could it be the voltage regulator? Just don't want to go the saga of buying expensive parts for nothing. Thanks,
  2. Hi there, I have an oldrunner Yamaha XJ600 (build year 1989) 51J. It has been running well but started to make trouble a month ago. The starter (notably when cold, usually not when warm) just turns the engine around for a few rounds and then stops with a noticeable click (not sure if this sound comes directly from the starter or somewhere else). This recurs when pressing starter button. The green gear light goes off as well when pressing the button and comes back after releasing it, the red oil indicator is dead all the way. Kill switch appears to make things a bit better when turning off and back on. After trying to start for 5-6 times (pressing starter button and turning kill switch on and off), the starter turns a bit more and more and eventually is able to start the engine. After that it runs well and does not do the trouble when restarting (warm). Leaving it for a night will end up in the same cycle. Any suggestions? The battery is charged. Just wanted to check if anyone has had similar problems and can direct me a bit before I dismount anything. Thanks,
