Cainmurphy
  1. Yes read from the positive and negative on the battery like I said I first bought a new loom still the same then I bought a stator which now the headlights and rear light works old stator was fried but still getting no charge to the battery only thing I can thing of it being is the regulator/rectifier.
  2. Ok I've put a new stator on headlights work fine but the battery still sits at 12.5 v when running could the regulator be the problem thanks again for the help
  3. Ok thank you will have to see if I can find one
  4. Ok update I ordered a new loom put it on and still the same battery sits at 12v when started no increase when I put the reader direct on the stator wires I get -0.34 so must be knackred if reading a minus voltage ? Guessing best thing to do is send it away to get rewound
  5. Ok I'll have a look at this when I'm with my bike can anyone confirm whether a 3bn loom would work same as the 3rm ?
  6. What should my battery be reading if it's charging?
  7. Hello guys just bought myself a Dt125r project excited to get it all road worthy how many others here have one?
  8. Hello guys be great if someone helps me fix my problem I just recently bought a Dt125r with a problem with the headlight and back light not working thought would be easy but can't figure out what's wrong I've studied a wiring diagram and have noticed the headlight runs from the stator? But my stator seems fine as bike starts etc without battery connected . The loom that is kn the bike is a 3rm I was just wondering if this is the right loom or do I need a 3bn? If it is right any ideas to figure out what's wrong?
