achilles370
Everything posted by achilles370
  1. I recently got my tires changed on my bike and the electronics started acting up. My horn, turn signals, headlight and back light to the tachometer and speedometer flicker and increase in intensity when I use either the back brake or the front brake. The horn does not work unless I also hold the brake. Also the turn signals stay a solid light instead of flashing like intended. I have been chasing wires and trying to locate a potential ground for the bike but I can't find any. The ground from the battery just joins up with a few other black cables that I assume are also grounds for the other electronic parts and are twisted together. I tried to clamp said cluster of cables to the frame to see if that solved the issue but it did not. If anyone has any ideas please let me know. Thank You.
