aircooled
  1. Yeah! If in doubt give it a clout? lol, I will go out tomorrow and try it mate, thanks :-)
  2. I`ve just youtube`d it, then checked out eBay for a solenoid, I should be able to swap it out myself no problem, just hope it is the solenoid/relay Thanks for your advice :-)
  3. Hi Airhead, yeah, it was turning over but not firing as I had ignition off, So should I remove starter motor and then check for ???? I`m not the best with electrics and have never seen inside a starter motor :-( As soon as I reconnect the battery, it turns over
  4. Hi all, I`m in need of a bit of expert advice (so whats new lol) I am not exactly mechanically minded, but will give anything a go with a bit of help. I last used the Draggie in November for a Remembrance Day parade, got her out last week, started up fine, left running to warm up, then when I switched off, the starter motor was continuously turning even with no ignition on, I removed the key and it was still turning, I had to disconnect the battery to stop the bloody thing, solenoid?? What do you guys/gals think?
  5. Hi all, name is Rob, ex military (RA) member of the Armed Forces Bikers Charity Riders, riding an XVS1100 (51 plate) when it bloody works :-( Exiled Geordie living in Northampton, looking to boost my minimal knowledge on all things mechanical. Ride safe.
