ashwin0731
  1. hi,, "I did some additional research and learned C3 cheek pads cannot really be used to tighten up the C3 Pro but C3 Pro cheek pads now offer a wider variety of thicknesses compared to when the C3 Pro was first introduced. You can now tighten up the fit of a XL C3 or C3 Pro by adding C3 Pro XS cheek pads. Here are the thicknesses for the various C3 Pro cheek pads as they would come from the Schuberth factory: 15 mm C3 Pro cheek pads are used in the small, large, 2XL and 3XL helmets. 20 mm C3 Pro cheek pads are used in the XS and medium helmets. 30 mm C3 Pro cheek pads are used in the 2XS helmets. I think this effectively means those with an XL C3 or C3 Pro who find the large too small and the XL too big can use the 2XS (30 mm) C3 Pro cheek pads to accomplish what you did in your review. The C3 optional cheek pads are no longer available but the same thing can be accomplished with the XS C3 Pro cheek pads. Some of the vendors of Schuberth like RevZilla state you cannot swap cheek pads between shell sizes. This did not make sense to me so I contacted Schuberth and they stated there is no practical reason you cannot swap C3 Pro cheek pads into any C3 or C3 Pro helmet. If there is a thickness which will improve the fit, Schuberth said grab the thickness of pad you want and it will work in either helmet and either shell size. I'm not sure how helpful this is but I've grown to greatly appreciate the content you guys provide. I pass it on in case it could be helpful to your readers. If not my feelings are not hurt if you simply discard the information. Thanks for the great content you folks provide." PREVENTATIVE VEHICLE MAINTENANCE
