chris_peake
Everything posted by chris_peake
  1. Does it have a manual or electric choke? Will be your choke Sent from my SM-G930F using Tapatalk
  2. Your welcome, dirty fuel really, it it hadent been started in a long time, when you started it, all the old shit fuel had gone into the carbs and caused this problem Sent from my SM-G930F using Tapatalk
  3. That's true, if the carb is clogged, the engine will run rich and the engine will get hotter, no if it started good the first time you looked at it and it's been sitting for over a year, my best bets are the carbs need cleaning and it's along time for fuel to sit there, clean the carbs and I can almost promise you it will be fine, but I would check over everything aswell, change water coolent, and give it a full service, check all hoses bla bla bla and will stop any future problems Sent from my SM-G930F using Tapatalk
  4. Yes it's the top one, take off the metal clip and try twist and pull or just pull it hard, it will come off, or to make it easier, heat the rubber where the metal clip was with a hair dryer or heat gun or can even pour boiling water on it to make sofen the hose and will pull off much easier, but with a strong pull it will come off Sent from my SM-G930F using Tapatalk
  5. Drain it from the fuel hose if it isn't suction pumped or Syfan it from the tank, clean the cards and you should be good, sounds like you have something stuck in the jet Sent from my SM-G930F using Tapatalk
  6. Clean the cards, put fresh fuel in, check air filter Sent from my SM-G930F using Tapatalk
  7. Loosen the bottom yoke (fork) clamps, put front wheel between your legs, give the handle bars a wiggle, tighten them back up and it will be back to normal Sent from my SM-G930F using Tapatalk When a bike falls over, the falks twist In the clamps Sent from my SM-G930F using Tapatalk
  8. Could be one of the fuses, pull the fuses from the fuse box and see if any are burnt out? Sent from my SM-G930F using Tapatalk Sorry just seen that you checked fuses haha Sent from my SM-G930F using Tapatalk Will it bump start? Sent from my SM-G930F using Tapatalk
