1978 DT175E restoration
Spent yesterday tearing the engine down. The PO told me he "rebuilt the engine" before he traded it to me, but after he also said he "took all the best condition parts from the three engines and put them into that one" I knew I needed to check. Good thing I did. Re-used rings and gaskets, changed out the cylinder without even a hone, heavily greased the connecting rod bearing, and a seized oil pump. This project is something else . Then, to add insult to injury, I took the frame to my brother today to have him press out the swing arm bolt. He did a rushed job and somehow cracked the top tab in two places. Didn't even push the bolt all the way out. Turns out he was late getting to the gym... still need to get the bolt out completely to really assess, but I might be doing some fabricating and welding of a new tab in the near future. Most of the shiny spots are just removed paint with no actual damage, but the cracks are concerning. Lesson learned. If there's a next time, take it to the professionals. It'll be worth every penny.
I think tonight I'm going to try laying the frame down on the floor, support it from the under side, then trying the WD40 and a hammer again. If that doesn't work, I have a friend with a press that I might ask for a favour.
Oh boy... I'm really looking forward to that now haha
Yikes! I'm a little uneasy about getting an angle grinder anywhere near there. There isn't enough room for the blade between the frame and swingarm
Over the last couple days I got into it hard. I decided I'm going to sand blast the frame and re paint it, so I started the tear down. Got the engine out and the bulk of the rear end stripped down. I'm at a stand still now though, because I'm having a serious problem getting the swing arm pivot pin out. Its seized pretty bad and it takes almost all of my 190lbs standing on the ratchet to even turn it. The nut came off easy enough, but so far heat, WD40, and hammering wont budge it. The swing arm wont even drop under its own weight... Anyone have experience with this at all?
- 1978 DT175E restoration
A little bit of back story: I traded a blown up 92 RM125 to a guy for, what he said was a complete, 1979 DT175 with no papers. Had a look over everything and although the ignition wasn't assembled, it looked all there. Came with two "parts motors" so what the hell, right? After having it in my garage for a couple weeks while I finished up a couple repairs on my other ride, I finally got to actually dig through the parts box and run some VIN numbers to see what I had. Turns out the bike is a 78 and the engine numbers match! Also, turns out its got everything to make a complete bike. Catch is, its all for 3 different years. Closest I can figure is, he had the 78 and something happened to the ignition. He found a 76 and stripped off the wiring harness and a few other parts, and converted the 78 to points ignition, discarding the original set up completely. At some later time, the points cooked, and he found the engine from an 80. When he realized that The CDI ignition from the 80 didn't plug directly into the 76 harness, he flogged the whole bike into my open arms haha. Needless to say, its a wiring nightmare. Ive decided to buy a used complete harness and ignition set up and re set it back to 78 electrical. Then I decided, "why stop there?" My first restoration project was born.- 1978 DT175 Ignition points?
Yambits is the best site so far! Thanks for the directions- 1978 DT175 Ignition points?
Finally got my Clymer manual. Look like I'm going to be a frequent eBay.ca customer haha. I checked all of the references that you guys gave and found some stuff, but eBay seems to be the way to go for most of it. There are a couple really good scrap yards in my area that I have yet to wander through as well. Thanks for the help everyone! Might have to make a project thread for this one. It will be my first restoration.- 1978 DT175 Ignition points?
I guess as long as it's from a year that had monoshock. I'm not too worried about original right now. I was even thinking of re jetting and running a pod filter and capping the oil pump to run mixed gas just to get it running, until I come across original. Thanks! Partszilla doesn't have a lot since most of the big stuff has been discontinued and is unavailable now. I'll have a look at the rest of these though. Thanks a lot- 1978 DT175 Ignition points?
Thanks anyway... I used to use 4into1.com for my Honda stuff, and regulatorrectifier.com for electrical, but neither has anything for this year of Yamaha- 1978 DT175 Ignition points?
I'm going to need a wiring harness, CDI, Stator, flywheel, oil tank, piston rings, gasket kit, air filter, maybe and air box- 1978 DT175 Ignition points?
Haha I would've had a heck of a time trying to figure out why things weren't working out! Now.... any ideas where a guys finds things like electrical parts for a bike from 1978? I found some stuff on eBay, but I'd rather find a reliable resource for online parts, since I'm going to need a few other things. Any suggestions? Seems like parts for the 78 and earlier are almost completely unavailable.- 1978 DT175 Ignition points?
There is! Thanks for pointing that out. It never would've occurred to me, but the harness is actually off the 76...pre CDI.- 1978 DT175 Ignition points?
Hopefully my clymer manual shows up soon. I'm not sure what out of this box of parts even goes on this bike anymore. Haha Both frame and engine numbers start with 2A7 however I have parts motors with 559 and 3V5 prefixes. From what I can find, the one in the bike is stock and a 78. The parts motors are 76 and 80. - 1978 DT175E restoration
Vernjeggies
Joined
Last visited
