Keith Inglis
Everything posted by Keith Inglis
  1. Have you checked the low tension supply to the coils ? also have you cleaned all the earths and the multi connectors throughout the bike faults normally occur with those with poor connections
  2. I have gone back to Shoei fro an HJC is it a case of the padding in yours needing replacement because they do shrink and become uncomfortable and noisy. Keith
  3. I have had five BMW's over the years but the last one I sold for that reason they have got worse over the years I went to Honda and I have not looked back. Keith
  4. I had this with a s/h XJ6 I bought and I used two vices one each side to bend them back,
  5. Keith Inglis posted a topic in Classics
    Hi All I need a little advice please, I have a Yamaha XJ900s 1999 with 44000 on the clock and when it is running on tick over there is the odd semi regular clonk from what seems to be the alternator but it goes when you lift the revs up is this normal or should I pull the alternator and have a look ? Thanks for any advice Keith
  6. Diesel is corrosive, it is ok if you want to free something off but not for what you want. Keith
  7. I agree
  8. I ordered a tyre from a well known firm in Kent and was told it was in stock, after a week I phoned up to see where it was and reminded them that they had said it was in stock, Oh it is in stock they said in our werehouse in Spain ! it arrived three days later from Holland.
  9. 1000 miles two up ??? are you sure you are running the corect tyre pressures and the wheels are in line ?
  10. 30c up here in Norfolk too hot for me with all the gear on, put the bike away and got in the car with the air con on :-) Keith
  11. you will have higher revs and more fuel consumption for the same speed but it will excelerate a bit quicker with a lower top end speed :-)
  12. Air cooled, well the only two things I can suggest it to make sure the fuel mixture is not to weak and check the timing, it will run hotter if it is retarded or running weak, otherwise it might be as others have said you have nothing to worry about. Keith
  13. That would be a good start to check all connections first.
  14. Ok I assume the bike is water cooled ? if it is check the water pump is working correctly the rad is not blocked ristricting water flow, the thurmostat is working and all hoses are free and not blocked, if it still over heats you will have to look at the water ways in the barrel etc, oh and has it got a fan ? is that working ? good luck and I hope you find the problem, and as somebody mentioned the compression seems a bit low there might be gasses leaking in to the block ? Keith.
  15. Yes above and check the battery charge is up to sctatch. Keith
  16. Well I do not know for sure but is it a plug to protect the block if it gets frozen a bit like a core plug ? is it a soft plug or a hard one ? mayby you can replace it with a new one, have a look on the parts list and see if it is listed as water is coming out it is in the waterway and not the compression chamber. Keith
  17. if it is hydraulic is there air in the system ? if it is cable has it got the correct play in the leaver ? if all is well you will have to follow the advice above and strip it down and inspect it as per the book normally when it is difficult to change gear or select nutral it means the clutch is dragging and not releasing correctly Keith
  18. Sorry to hear that hope you find in one piece, I will keep an eye out you never know it might get over this way ?
  19. Ok Guys and Girls I have found one in Holland Thanks anyway
  20. Keith Inglis posted a topic in The Bar
    Hi all, has anybody got a right hand yamaha muffler for a 1999 xj900s diversion in good nick they would like to sell by any chance. Keith
  21. I second that
  22. Keith Inglis replied to Alex's topic in General
    Thanks for your help :-) Keith
  23. On both my yams the relays click when I turn the ignition on but not when I pull the clutch, as it is running badly is there a short on the wiring, can you pull the tank and have a good look perhaps with a meter as well ? Keith
  24. Spike does this happen with the ignition on or off ? Keith
