Jazza
Everything posted by Jazza
  1. Jazza posted a topic in Classics
    Hello All. I have an 1976 RS 125. Both the steering and seat locks are damaged, but I have the original Key. If I get replacement locks, is it possible to remove the original lock barrels and replace these with the new locks so I can keep the original lock and not end up with two or three different keys. I have stripped the original seat lock down, but cannot work out how to remove the barrel. How do you remove the original barrel? Thanks.
  2. Hello I have a 1976 RS125DX, The early 480 model. I dont know if the parts will be the same, bit I have the original parts catalogue with the part No`s. I could sent you a copy of the brake caliper parts if you still need them?
  3. Jazza replied to Jazza's topic in Classics
    Thanks. Yes thats what I`ll be doing, Left hand helicoil kit £100 plus pounds, Already seen some that will do,
  4. Jazza posted a topic in Classics
    Hello All In the process of restoring a 1976 RS 125DX. Almost ready for it`s MOT, I know they are not required for a MOT but I have a problem. The right hand mirror threads are useless, The mirror wont screw in , the threads are well worn, IT is a Left hand thread. Anyone got a Left hand helicoil/recoil kit? Any suggestions for repairing it? Thanks
  5. Jazza posted a topic in Classics
    Hello All. Im a new member and posting for the first time. A bit of history first before my Question. Meny years ago when I was 17, I bought a RS 125DX, in Yellow. After Meny years of searching, I came across one exactly the same, for sale,and an in the process of doing it up. I had problems with the lights and ignition, and have discovered that the ignition switch internals are broken!! The original part No is 505 82508 20 . Mine has 6 wires that go into a terminal block, and 5 loose wires with bullet connectors All the replacement ones I can find advertised, only list 10 wires in total, and the wires are different colours and in different positions from mine, obviously this may be because the manufacture uses different colours from the original. Has anyone got a RS 125dx,RS 100 and had to replace the ignition switch? What type of replacement switch did you use? Thanks Any one got a second hand one for sale???
