vaughn1274
Everything posted by vaughn1274
  1. Thanks I did find a repair kit. A company called Speed Moto Company had my petcock rebuild kit and my carb boots I was looking for. They specialize in 70's and 80's Japanese bikes If you guys are looking for something check them out..
  2. My question is would I be able to use a rebuild kit from another yamaha for my radian?? I cant find one for the radian and I know the fz600 used the same carbs. I looked it up and found one for it and it looks like the diaphragm is the same as mine..
  3. My clutch was slipping also and my buddy was helping me with it and he adjusted the clutch cable and it doesnt slip anymore. there is alot of play in the handle just the opposite as I would think it to be
  4. Mac makes a set, there is a set on ebay over on July 15th ebay auction # is 260136511402 the buy it now price is $330 plus $32 for shipping
  5. Yeah I still get spark, I think I have it narrowed down to the fuel system, it did it to me tuesday, Pulled the air filter and shot some starting fluid into the airbox and it started up and ran fine till it burned the starting fluid..I am going to try to drain the tank and make sure its not plugged up and pull the carbs again if need be, I still have fuel in the bowls when it acts up, just wondering if there is enough
  6. I am not sure how you bled them. But I always use one of those bleeder bottles from the auto parts store.. You can get them for less than $10.00 and they work very well. I have tried to bleed motorcycle brakes before without it. I just dont seem to be able to pump them up, but with the bottle they do good luck
  7. The specs say it is a TCI Full transistor ignition
  8. My radian runs really good for about 5 minutes and then just quits.. I have fuel in the bowls and spark, but it will not start back up until it has cooled down...any suggestions??
  9. There doesnt seem to be any diaphrams on these carbs..
  10. I have an 86 radian and I am not getting any fuel into cylinder #2.. I have checked the carb jets for blockage needle looks good, There is fuel getting into the bowl. Pulled the plug and it is white all the others are brown to light black. Has spark and compression.. Any help would be greatly appreciated
