Mark Halford
Everything posted by Mark Halford
  1. ok thanks for your help I'll buy a manual and a set of jets as see how I get on
  2. drewpy. I'm not to sure what I'm measuring on the carb to determine the size any ideas?
  3. ok I tried measuring it and got 24mm that sound right? I'm not sure what I'm doing with the pilot though lol shall I send u a pic of the carb?
  4. drewpy. ok mate cheers I'll order that kit asap. it will fit aerox yeah? and what is the pilot jet?
  5. drewpy. Ok I'll keep the carb, I think I'm running a 76 jet in there atm what size jets you recommend I buy? blackhat250. Imnot too sure about the plug I can't get it to run well enough to take it for a run lol is the pilot jet the main jet? thanks
  6. ok bud what size jet and carb u recommend?
  7. I think I might take it to a specialist
  8. ok I had the crank seals done twice and I'm pretty sure there ok. I figured out its one and a quarter turns on fuel to air mix but I'm not sure if my carb is working correctly tbh its the only thing I haven't changed on the bike atm also what size carb and jet would you recommend? I'm running everything standard except for a technigas exhaust
  9. variomatic, it's got 2 brand new crank seals and a new air filter but I'm not too sure the air box is air tight, I'll try that first. I also turned the fuel to air screw fully in and the bike kept running is that supposed to happen? thanks
  10. hi I've got a Yamaha aerox 100 2002 and I'm experiencing power problem so much I can even hold the bike back. I've cleaned the exhaust and carburettor and tweaked the fuel to air mixture but It still lacks power, I think the carb might of had it. any ideas much appreciated thanks mark
