Front end swap
Finally got a front end sorted (actually two front ends), now I'm in desperate search of a rear wheel and final drive unit, can't find anything on eBay apart from America. Might try a virago rear instead?
Front end swap
I'm guessing that due to the top yolk being cast aluminium it became brittle under heat and then a roof joist must've fallen on it as its sheared off either side of the clamp. So I'm without yolks haha. The fork legs still look intact though. Are custom yolks much narrower than classic? As I said I just want to go for something a little skinnier. Really appreciate the help
Front end swap
There aren't many local to me that seem to take on bikes, I'm pretty limited round here
Front end swap
Well unfortunately my bike burnt down and I'm literally starting again. Xvs front ends are coming up pretty pricey and I was after something a little narrower than the stock front. I do still have the legs though as they were untouched by the fire. So really all I need is the yolks
Front end swap
Hey does anyone know if a xj600n front end would fit on a xvs650? Any help would be great
New to the forum, glad to be part of it
Just wanted to write a little introduction for you all. My names josh and last year I purchased my first bike; an xvs 650. I made a large amount of progress and had just begun to hardtail and convert it to single back bone. However unfortunately it burnt down along with all my equipment. So now I have begun the task of rebuilding it from the ashes. My engine is going off for powder blasting this week and I'm going to continue on the frame. Unfortunately a lot of my parts were destroyed or crushed by the rood of the building it was in so I need a little bit of help finding a rear wheel and any information of what other front ends fit. I will post in the proper sections shortly but thought I'd give you all a little over view. Any help would be great! Cheers
Joshmcs
Joined
Last visited
