Shifter bar replacement XVS1100
That won't be long enough for the forward controls and foot boards but I appreciate you helping. I wonder if I can get an aluminium tube and tap the right sized threads either end. Or would aluminium be too soft for the rigours of shifter changing.
Oh crap, sorry and thanks for the reply I didn't get a notification
Is it just me
Thanks Campaman I think it's mostly after market stuff, like the sissy bar, the problems are only with the Allen key type bolts.
Is it just me
I have a 53 plate Dragstar 1100, and am finding every bolt I try to remove, to fit saddlebags for example but the hex heads on the bolts are soft. So much so that I am finding them rounding off before I can loosen them. having to use my dremel to square the top then replace them. Is this common ?
Hi guys 'my shifter bar on the forward controls come loose on my way home from work by the time I managed to safely stop, the bar is trashed threads gone completely. any idea if the bars can be purchased separately ?
Just discovered how to polish aluminium
That would be cheaper than a new chrome part thanks
yes the rear plastic clip on accessory, probably be better to take it off for now, but cannot seem to be able to find anything similar to replace it with.
Thanks for the advice, seen some YouTube clips on totally removing the lacquer and going bare metal polished. Like the sound of that lol any ideas where I can get spares like the one below,
Well as the title says, my dremel has been working overtime. now have near mirror finish to my old stock clutch ' brake levers current ones chrome all flaked off, 'mirrors look awesome, Been looking for reasonably priced accessories to replace some old plastic chrome parts that are damaged, anyone got recommendations as struggling to find parts. Might struggle with these thanks
Old exhaust polish / rust
Thanks will give it a try
Hi everyone, silly question time, I have been trying to remove rust and polish The old stock exhaust on my Yamaha dragster 1100. This is a test as I have new exhaust on the bike, I have noticed that the rear of the old exhaust is not mirror finish chrome not sure if it was like that normally or excessive polishing has dulled it. tried to take a photo as below. or maybe not as cannot upload photos for some reason. not a bad result looks much better
Gap between saddlebags and exhaust ? [heat]
Thanks for the info, will look at sizes very carefully to ensure there is sufficient gap
Hi there nearly ready to buy some saddlebags for my dragstar 1100, 'just wondered what opinions are about the heat from the top exhaust, and gap or heat shield, any experiences ? thanks
Anyone purchased from celticafes.co.uk ?
Thanks for the heads up
Found this site after searching around on Facebook. Seem really well priced especially saddlebags. Seem a little too good to be true, has anyone had any experiences good, bad or indifferent ? thanks in advance
Phil72
Joined
Last visited
