dtr1994
  1. evening guys im having a problem with my dt 2003 i turn the ignition on the N light will work and indicators but headlight wont unless the bike is running but if i stop reving the headlight dies also when i brake.do i need a new Rectifier?? thanks for the help
  2. moved the reed switch road very busy at the moment will see if it made a difference later
  3. hi 2 wheels thanks for the reply ill check the reed switch tomorrow iv just found a post that says its a speed limiter not a rev limiter i got it the wrong way round so will give that a go,im really liking the 2 stroke! and yes the brakes dont seem to good even tho they were changed not long ago,,so would you say its defiantly restricted if its only doing 60-65
  4. hi there! just brought my 1st yam this weekend a 2003 dtr 125cc lovely bike really enjoying it only thing is that it pulls like a train thorough the 1st few gears will power wheelie in 1st easily but top end is stopping at around 60-65 MAX rarely get to 65 now i have read about a read switch behind the head light but if i had read correctly this also stops the rmp going past 7000 the bike will rev freely to 10 when in Neutral,any ideas how to get that bit of extra top speed as iv read it should have a bit better top speed, thanks here is a pic
