Jack R1
Everything posted by Jack R1
  1. Jack R1 posted a topic in The Bar
    https://www.youtube.com/watch?v=2CGYukjM4Vg&feature=share
  2. Jack R1 replied to Jack R1's topic in Projects
    I'd love to still follow this but currently it's sat in my workshop with a blanket over it. Been a hectic year with racing season on us. I'm need to get the rear subframe made then it should be full steam ahead
  3. Well done
  4. Well, what a cracking weekend that was. Seeing and listening to all the stuff going on behind the scenes was something else, professionalism taken to a new (maybe too much at times) level. Thursday night started by walking around the paddock with a cold beer and then into pitlane to see the MotoGP bikes started and ran through the gears Friday work started at Pit Lane exit for Free Practice Saturday more of the same and then qualifying (did you know that during MotoGP quali and races you cannot walk across pitlane anywhere without a helmet on ?) Sunday pit lane exit for warmups followed by grid boards (I was on Row 2) and yellow flags for the start of the races. I then had a brisk walk to the end of pitlane exit, which is quite a way around Copse to do the blue flag. Seeing as at that level no one comes in and back out I managed to watch all the races with a grandstand seat . The weekend ended standing under the podium All in all, a superb one
  5. Jack R1 replied to Jack R1's topic in The Bar
    Started on the button after two days in the van. Ticks over lovely off the choke. Little bit of corrosion here and there that will get tidied up. Brakes need pulling apart and cleaning and I'm not sure if the chain will need replacing but I'll remove and soak in some oil overnight Apart from that I think its all good. More than happy
  6. Jack R1 posted a topic in The Bar
    Having not had a road bike for a couple of years my NCB was close to lapsing (25 years +). I decided to ask around some friends of they new of anything. I found this 2001 Fazer 600 wthat has been stood still or 2 years. The owner put a new battery on it and it fired up almost straight away. Now a general clean up and service and we are good to go for £500. Even got spare plastics for it Yamhas are back in the majority of 3 to 2
  7. Jack R1 replied to Jack R1's topic in Naked
    We'll see
  8. Jack R1 posted a topic in Naked
    So, it looks like I'm going to be the owner of a 2001 Fazer 600. Anything to look out for / keep an eye on ?
  9. Jack R1 replied to blackhat250's topic in Projects
    Don't you hate it when the simplest things give you unplanned work Looking really nice
  10. Jack R1 replied to Jack R1's topic in Projects
    End can acquired from a Triumph Thruxton
  11. Jack R1 replied to Jack R1's topic in Projects
    I'm pleased with it generally but still loads to do Remake the rear subframe to allow the lightweight (but large) battery Make the tail unit undertray (not looking forward to that as it will need rolling and bending) Full wiring loom Full exhaust system then the little jobs that takes ages start !!!
  12. Jack R1 replied to Jack R1's topic in Projects
    It's been way too long since I've done anything to this. The bikes has been in bits scattered between my work and home garage. I've got the bit between my teeth again so have got the thing back together again I've sourced a nice rear brake disc for the SV rear wheel Ive even tidied my workshop up to make it a bit more inviting
  13. Jack R1 replied to Jack R1's topic in Projects
    Sorry for the late reply. I have been crazy busy at work and not touched this (other than stripping it down to bare bones for the umpteenth time. Will be picking it up and running with it again very soon
  14. Speak to ignitech. They'll be able to make up a direct replacement for around £150 http://ignitech.cz/en
  15. Jack R1 replied to Jack R1's topic in Projects
    The sparker TCIP4 inductive programmable ignition along with has turned up from The Czech Republic Nearly ready to set about making the new loom up
  16. Good luck with the build
  17. As far as a clock mount goes you may struggle. if I were you I'd knock up a template and go to a small fabrication shop Sorry I can't be any more help
  18. Jack R1 replied to fordrallycar's topic in The Bar
    http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1311.R8.TR11.TRC1.A0.H0.X5.5%22+headlight.TRS0&_nkw=5+1%2F2+headlight&_sacat=0
  19. Jack R1 replied to Jack R1's topic in Projects
    First draft of the rear brake plunger bracket
  20. Jack R1 replied to Jack R1's topic in Projects
    I think this is the one you are looking for http://greasygreg.blogspot.co.uk/
  21. Jack R1 replied to Jack R1's topic in Projects
    I think that would be Nanno. It's a great build !
  22. Jack R1 replied to Jack R1's topic in Projects
    Just a quick one to say I'm still here but struggling to find any time at all to work on this. I have had time to dry fit the 2 into 1 manifold and 40mm flatslide carb. Looks so much better than the standard twin carbs [thumbsup]
  23. Jack R1 replied to Jack R1's topic in Projects
    Can't wait to see it. get a thread of the build going
  24. Nice work sir Levers need to be black though
  25. Jack R1 replied to Jack R1's topic in Projects
    Hardly any difference between the two mate. Just bearing and therefore spindle size. Why are you going to the Yamaha front and Suzuki rear ? The reason I went for the GSXR front ws to match the wheel to the SV. You will have different shape wheels the way you are descrbing
