xibradersx
Everything posted by xibradersx
  1. Hiya, basically I've got a yamaha dtr 125 2001 model and whenever you put into dipped beam the front light turns off, but the rear light is still working and when you put it on main beam the front light turns on but then the rear light turns off, I've fitted new bulbs still hasn't solved the problem if anyone has had the same problem or knows anything about it you'd be a great help. Cheers brad
  2. Cheers you guys are a star!! so would you recommend putting anything over the hole to cover it up so no shite actually goes in there, or just leave it how it is? Many thanks Brad
  3. Hiya, sorry I'm new to this, I've got a Yamaha DT R 125 2001 and no I'm no expert but I've got some knowledge on the basics, and very concerned as haven't found nothing on the internet about it, the thing was making me concerned is its bone dry theres no oil leaks, water leaks etc coming out of this hole, I'm trying to upload a pic as its hard to explain where it is exactly, but its not letting me upload anything bigger than 0.49 mb if you could help you'd be a great help cheers Brad
  4. Basically had a look underneath the engine today and found a little hole in my engine casing, I'm no expert but I'm pretty sure there shouldn't be a little hole there, if someone could help me would be great, on any advice etc as the only thing I can think of is some sort of drainage system
