begbie
  1. Hi there, what I normally use is a tool called a mitivac, which is attached to the bleed nipple and the tool causes a vacuum when used pulling the fluid through, another way is to attach a piece of rubber hose between the bleed nipple and an old oil can fill the can with brake fluid and pump the fluid in reverse, this works well with clutches. The mitivac has never let me down. good luck..
  2. begbie replied to liquidcooled's topic in The Bar
    Hi Begbie here, new member too auld to say but auld enough to keep quiet, i own a 900 divi,green with a few miles on it just like myself I am from Scotland (Gods back yard). only happy when the bike is on the road and the wheels are turning....
  3. Thanks mate may stop worrying about bits falling off cheers
  4. Has any one came across an engine vibration @3,500rpm till about 4,500rpm, yes cruise its a real bind, have tried carb cleaner carb balancing but with no joy, has anyone got a remedy?
