richardb
  1. Wow, what a great design ................... not. Can I install foam or paper air filters directly at the end of each carb ? Then, if that's my plan I could just destroy the airbox and cut ut up to remove it. Any suggestions for potential air filters that will fit and look good, and work ?
  2. Yamaha FJ600, 1984, Need help with Airbox removal -------------------------------------------------------------------------------- I want to remove the airbox. It is jammed into a little triangle of the frame below the seat. I have the carbs off, the battery and battery holder off, the airbox loose. It does not look like it will come out without removing other components. Will removing the starter allow it to come out? Otherwise it appears the engine must be moved or removed. Help.
