YPVSTony
  1. Are you saying you are only getting power for the lights, horn.indicators and handlebar panel lights with the engine running? If so it may be worth checking to make sure that the main fuse/s hasn't blown. Tony
  2. Have been looking at this recently as saw an article about it on the web. I was going to get some of the screwdrivers of ebay but they were quite expensive but found a dealer who does the "Motion Pro" tools here in the UK and they do the packs of JIS bits in the #1,#2 and 3# sizes as here http://www.dirtbikebitz.com/motion-pro-tool-jis-cross-bit-2pk-p-76638.html?gclid=CPyihtz03dMCFaa17Qod3BMLqg&utm_campaign=products&utm_medium=BaseFeed1&utm_source=GoogleBase1 Also after a bit of research on the web found out that Tamiya who do the R/C model cars also do their own screwdrivers that are JIS Standard but only in #1 and #2 sizes. Tony
  3. You can get plastic protectors like this http://www.ebay.co.uk/itm/Black-Universal-Motorcycle-Fork-Leg-Stanchion-Protectors-Easy-Fit-/400459931906?hash=item5d3d45a102:g:jsgAAOSwKIpV-VuS#ht_1257wt_1055 that fit around the leg and protect the stanchion, and the ones shown are universal that are split at the back so you open them up to go over the leg so no removing of the forks is required. Tony
  4. YPVSTony replied to Mr Bignel's topic in The Bar
    You want Guy Martin then.
  5. YPVSTony replied to Mr Bignel's topic in The Bar
    Could be worse, they could have given the job to Jeremy Clarkson.
  6. Sounds like the carb pilot jet could be blocked. Once unscrewed you should be able to just see through it or spray some carb/contact cleaner through it to see if its clear (Don't be tempted to poke bits of wire down it).
  7. YPVSTony replied to Variomatic's topic in The Bar
    It's worth checking while you have the clutch apart, the slots in the clutch basket where the "Tabs" of the friction plates locate against for indentations due to wear which can cause the plates to stick. If not too bad these can usually be cleaned up with a fine flat file. Also worth checking the grooves in the clutch centre where the metal plates locate in for the same wear.
  8. YPVSTony replied to up.yours's topic in The Bar
    There is a selection on the RD LC website here for £50 http://homepage.ntlworld.com/ultimatelccrazy/html/Decals%20&%20stickers%20.htm Tony
  9. It always used to be on Yamaha's that the RH side mirror (Throttle side) had a left hand thread where it screwed into the handlebar mount and the LH side mirror (clutch lever side) had a normal right hand thread.
  10. YPVSTony replied to Andyb67's topic in Yamaha Workshop
    If it is Black and quite thick it will be the negative wire from the battery negative terminal.
  11. Assuming you've taken out all the screws, certain there is 9 in total, it is usual for the clutch cover to get stuck on the O ring that fits on the end of the alloy coolant tube that is seen in your photo where it fits inside the clutch cover to seal the coolant from the gearbox oil. There is also a wire circlip on the tube which is by the O ring to hold the tube in place when you put the clutch cover back on. Try spraying something like WD40 in the area where the tube fits in and try gently wiggling the clutch cover off. Be careful trying to prise off with a screwdriver as you'll end up damaging the gasket surfaces. Tony
  12. Looking on the Yamaha UK website under manuals it says the XVS1100A is fitted with tubed type tyres. Did you get an owners manual with the bike ? It will tell you in there. You can't just fit a tubeless tyre on wheels that were designed for tubed type tyres.
  13. You will probably find them on the rubber intake manifold between the carbs and cylinder head with rubber caps on with clips holding them on as mentioned.
  14. I think I would give Yamaha UK a ring on 01932 358000 and have a friendly chat with their warranty dept and explain the situation as they may still honour the claim. Found this on the web and it looks like you're not the only one to have a leaking rear shock http://www.visordown.com/road-tests-used/buyer-guide-yamaha-fjr1300/14369-2.html. If you look on the Yamaha Motor UK website and look under services / modification checker you can enter your VIN and see if there have been any recalls in that area. Tony
  15. And with all due respect I will stand by using the pump system. One of the problems with premix is that it uses the same oil ratio throughout the rev range so the engine is given the same amount of oil pottering around town as it is running flat out on the open road. I remember my first road bike which was an FS1E which you had to premix at 20:1 and I remember it was a regular job to remove the cylinder head and barrel to decoke the piston and rings and to remove the exhaust and baffle to clean out the oilly buildup. I expect things aren't quite as bad these days with the availability of semi and fully synthetic 2 stroke oils, but I know on my 1983 RD350LC2 when I remove the exhaust baffles after several thousand miles there is hardly any oil or carbon buildup on them and that is with using a mineral based oil. What diaphragm are you refering too ? The oil is gravity fed down from the oil tank to a mechanical pump where it is metered out via the throttle position and engine RPM and then pumped into the inlet tract. Apart from a couple of oil seals in the pump there is no diaphragm in the pump to fail. Regarding pipe blockages the only time I have heard of this happening is when the bike has been sat for many years and the oil has gone bad. The oil lines all have retaining clips on them to keep them on so I expect where you've heard of the pipes falling off is where people have not put the retaining clips back on the pipes.
