victor400
Everything posted by victor400
  1. victor400 replied to Kishkumen's topic in Classics
    could be the starter then, or alternator if the battery is not holding a charge, check the length of the brushes. Get a Haynes repair manual There are several sites that have OEM parts diagrams for older Yamaha bikes. Starmotorcyles.com is one. xjbikes.com also has lots of info on xj motorcycles
  2. victor400 replied to Kishkumen's topic in Classics
    Was the battery new? It does not take long for an old battery to lose a charge and not be able to keep a charge.
  3. just made the same switch, they will indeed fit
  4. victor400 replied to victor400's topic in Classics
    Thanks for all the replies. Here is a list of things that were wrong with this bike. 1. Points were improperly set, left side was grounding itself. 2. Air filters old and falling apart. 3. Carbs seriously gunked up. Swapped them out with a set from an 81 400 that were amazingly clean even after sitting for years, cleaned up quickly. 4. Pilot jets on original carbs slightly mangled and unremovable. right side had air flow carb problem New clean carbs, points set correctly(timing to follow no timing light yet, new breaker plate ordered) and it fires up. Mostly this is a list to help others with similar problems, and thanks for the help
  5. oil should be added to just below the top of the sight glass you should be able to see a small bubble Haynes manual states XJ650 11N and XJ650 RJ 2.95 liter or 6.2 pints with filter all other XJ650 2.65 liter 5.65 pints with filter no disrespect to this site but you might want to check out XJ Bikes.com lots of XJ info there
  6. victor400 replied to victor400's topic in Classics
    Swapped out the coils and can get spark from previously dead plug. So far I have traced it to a two prong connector for red and white wires(sorry I don't have a wiring diagram yet) it connects both red and white wires to a single red and wire in the harness. One side works with both coils the other doesn't. I am confused one connector(brass) that connects both wires but one side does not conduct current!!
  7. victor400 replied to victor400's topic in Classics
    went over the carbs again, now there is no spark from the left plug there is spark to the right, how do I check the coil for viability? the wiring and connections do not appear corroded
  8. victor400 posted a topic in Classics
    Hello, new to the forum but not new to motorcycles. I currently have a Seca 750 that is running well. I just bought a 1978 xs400E that has been off the road for at least 7 years. I got it started after a quick and dirty carb clean, unstuck the floats and slides. After it was running I noticed the right muffler(as I am sitting on the bike) was much hotter than the left. Bike runs rough but I expected that. Any suggestions on where to go from here?
