mountainman22
Everything posted by mountainman22
  1. Hi all, i have a 1976 dt175 that i am in the process of renovating and having a little trouble with the clutch i have replaced the plates and springs and done the adjustments but can't get it to disengage when the clutch lever is pulled in the plates do not move have i tightened the springs too tight or could it be another issue the cable is fine.thank you.
  2. mountainman22 posted a topic in Classics
    Hi everyone,i have a 1976 DT175 also a AG100 1973 i require assistance as i am renovating the DT and the rear wheel is stuffed will the rear wheel from the AG fit?the hub's are not the same as the AG has a 4 point drive which has the sprocket attached and that fits into the hub so it is quite a lot wider than the DT. or has anyone got a spare wheel for the DT any advise would be appreciated.
  3. hi everyone,i have inherited a 1976 dt 175 and have a question regarding missing parts,is there a reason why someone would remove the head/tail lights and oil tank/speedo and just leave the tacho i'am a little bewildered why this would be unless its for a specific reason.any ideas please. thank you.
