dargoion
Everything posted by dargoion
  1. How did you planed to send power from engine to the wheel? Trimis de pe al meu SM-G900F folosind Tapatalk
  2. dargoion replied to ldwonearth's topic in General
    Check maybe you have a faulty fuse somewhere, yes a old car coil will work at least to see if you will get a spark but im my opinion either you have a short circuit somewhere or just a fauty fuse Trimis de pe al meu SM-G900F folosind Tapatalk
  3. Glad you ok Trimis de pe al meu SM-G900F folosind Tapatalk
  4. bike was old he was crazy ... i had a problem with my xt the chain got lose and rapted in the sproket at 150 km i was lucky that the force shreaded the chain and the wheel started to turn again... grouch is right could have been sooooo muchhhhh worse!!!!! Sent from my iPhone using Tapatalk
  5. my xt did the same thing:/these yamaha brakes are quaite a pain in the arse!!!! hers how i fixed it:took the good old repair manual and read it:when the brake instal is all dry when u fiil it up u must leave the liquid settle for a few hours just like blackhat said or like i did i blled it a few times with the cap on the a few times with it off then filled the thank and go to work after i cone back i bleed it again! when u blled it make sure u press the handle until it hits the handle bar!iff still dont works try to fill the liquid thank then put liquid in that rubber sealing then put the cap back on! keep us posted Sent from my iPhone using Tapatalk
  6. great tks alot slice Sent from my iPhone using Tapatalk
  7. hello all:) got to ask something :do i need to put locktide adesive on the screws that hold the dampers in place on the front fork? :/ 4 on each side? Sent from my iPhone using Tapatalk
  8. what situations mate? Sent from my iPhone using Tapatalk
  9. fond out whats the diference but i still dont know what to chose :/ Sent from my iPhone using Tapatalk
  10. i want to change the brake plates and i see that are 2 tipes ceramic ones and metal ones the price gap is small only 4 euros diference for the metal ones now really idk what to choose:( whats the diference between them? Sent from my iPhone using Tapatalk
  11. but i drowed blood actually the hammer did a few advices for all who tries to do it first and most important get a good broom handle mine almost braked and get stucked inside second keep trying i did it after the fifth time:) tks Kevin for advices the hit the spot:) Sent from my iPhone using Tapatalk
  12. did it Sent from my iPhone using Tapatalk
  13. and it didn't make any sound to mi surprise:/ Sent from my iPhone using Tapatalk
  14. i jumped a large bump at hight speed and after a few days i seen oil under the bike i looked it to is and seen its comin from the front dampers i guess one off those rubber seals are gone ordered a new set off them and now i want to change them (if i manage to take that screw off) Sent from my iPhone using Tapatalk
  15. its losing oil i will try to use a impact gun and the broomhandle will keep u posted iff it worked;) Sent from my iPhone using Tapatalk
  16. hey all i try to remove the front dampers from the bike all rounded smoothly until i tried to separate the damper the screw from the downside is turning bit with no results:( any advices? Sent from my iPhone using Tapatalk
