3ProngApproach
Everything posted by 3ProngApproach
  1. Hi Everyone, Sorry about the delay, now for a quick update; Frame is chopped, currently being blasted and painted, all other bits and pieces are more or less painted (all matte black) Wheels are coming back red (i hope) Ordered parts; New drag bars Solo seat LED lights - including 3rd breake light (to be mounted at the back of the seat - not sure if ill use it yet) New tyres White wall tyre paint (fingers crossed it works) Carb Jet Kit Air filter Jobs outstanding Build a new battery box low down to hide all the bits and bobs build a small box for housing the air filter get an exhaust and baffles done (i got some nice scrap stainless pipe) Re-Jet as required I've no pictures worth putting up, but ill show the assembly as it happens. On a side note -, if this works out or not, im sure you'll agree, just messing around with a bike is probably the most therapeutic and relaxing thing a man can do...... and without the need to cuddle after! ANYWAY! back to work.... see ye later.
  2. 6 month holiday with a dual sport bike..... My day just got worse.
  3. Great idea, thanks. I wanted the look of the cone out the side, but the panel one makes the job so much easier. Now to figure out the exhaust..... i cut the original off in my enthusiasm... now i find they are like hens teeth..... oops.
  4. So you'll have to use your imagination a bit, this is the set up of the barb in relation to the cylinders. The intake is covered over by the rag on top, that's where the old air box connected and the distance from the top of the carb and the bottom of the tank is very tight, approx 40mm. The tank is flat underneath except for the hollow to sit it on the frame of the bike. I cant get anything on the carb direct due to the small gap, unless i drop the carb (cant see that happening) or raise the tank (and i don't think that'd even be enough), so, i was going to make a small box 40mm high to run the filter out past the tank on the side where the original filter box was. That make sense?
  5. Nice bike! I can safely say I've never seen rear suspension like that..... looks cool though. You'd want to have great faith in the bolts holding on that sissy bar leaning back as a passenger at 70mph Great find.
  6. Oh, this is the tank btw.
  7. One thing i am insisting on, is the new fuel tank which is off a harley, i think its perfect but it poses a number of problems ye might shed some light on for me. 1. Removal of the existing air intake and filter 2. Replacing it with a new (smaller) one that performs the same function 3. Re-jetting the carb Now from reading similar posts on here, this is potentially a major pain in the arse and i understand this is purely for the look, but i am determined to make it work. The distance between the top of the carb and the bottom of the new tank is at best, 40mm. My first thought is to custom build a steel or aluminium box with baffles that will direct the air into the top of the carb at the same-ish rate as the original intake system from a K&N filter pointed out 90deg from the engine. Then rejetting as needed. (i also have a related exhaust problem - but that can wait) Thoughts on that from anyone? I promise ill dedicate the unveiling of the bike at Ultimate Bike Builder to Yamahaclub.com
  8. That worked - thanks FAQ section. So that's what i started out with, the next pics are just of the breakdown of the bike, nothing ye haven't seen before, but interesting (maybe) none the less. I have so many questions.....
  9. Right so - Pictures, this first one is just to make sure i upload pics properly....
  10. Plusgas - thanks, ill check it out.
  11. That was my first thought. my only worry is though that they might try and off load what they have as opposed going off finding what i want, but ill check with them. Your 125 is (was) a cracker too btw. Im taking a lot of inspiration from it.
  12. Thanks Lads, see? great bunch of people!
  13. Hi guys, There have been a few really great bobber projects on here, and I've had my brother in law off load his one for small money to me. So I thought, why not? It's been left out in the rain for the best part of 7 years and it shows, during the strip down I used about a gallon of WD and rounded 60% of the bolts and screws on it.... Anyway, You might help with some forward planning. The look I'm going for is nothing unique against what the other guys did, but I do want to put the fattest tyres I can on it, particularly on the front. Has anyone experience with this? How big will I get away with? Are we talking batman tumbler big
  14. Hi, I actually have the same problem/question. (I had to cut mine off due to rusted bolts) Someone else here mentioned Biltwell exhaust kit, which looks good, and I have a friend who can weld. 2 questions though, will I get caught for import tax if I order it from the U.S? And beside getting a second hand set of original pipes (which I really don't want to do) are there any other options? Thanks,
  15. hi everyone, Just a quick intro... I took on a dragstar project and every time I asked google something, it sent me here. How could I not join? Great bunch of people here from what I've read, with some great insights and advice, so I'm looking forward to being apart of it. Dave
