pignapper
Everything posted by pignapper
  1. pignapper replied to pignapper's topic in Projects
    Oh forgot to say. The wife is away for a few days so can bring tank inside to cure in the warm..... while the cats away. Lol
  2. pignapper replied to pignapper's topic in Projects
    Tank just needs rubbing down then laquer. Nearly finished.
  3. pignapper replied to pignapper's topic in Projects
    All fixed
  4. pignapper replied to pignapper's topic in Projects
  5. pignapper replied to pignapper's topic in Projects
  6. pignapper replied to pignapper's topic in Projects
  7. pignapper replied to pignapper's topic in Projects
    The broken panel
  8. pignapper replied to pignapper's topic in Projects
    Top article that jimmy. Given me some good tips. Dont have the snapped off bit so was thinking of making a mould from the lug on the other side panel then using tie wraps, melt them into the mould to form the bit needed then ill weld it on like in that article. Worth a go. Thanks again.
  9. pignapper replied to pignapper's topic in Projects
    Hi guys, checked all the connections and swopped the wires over on the starter relay and....... wayhay it turned over. Bad news was that after putting laquer on the tank it crazed so had to strip it again. Never mind rome wasnt built in a day. Nice and sunny today too. One of the side panels has a damaged lug clip so will have think of a way to fabricate a repair. Any ideas guys and gals. Stay safe
  10. pignapper replied to pignapper's topic in Projects
    Thanks mate ill look at that in the morning.
  11. pignapper replied to pignapper's topic in Projects
    No. Its just folded up full of crap. It was like that when i bought the bike but it turned over then.
  12. pignapper replied to pignapper's topic in Projects
    Thanks jimmy. Got a trusty haynes. Im no electrician but working through the electrical diagram.
  13. pignapper replied to pignapper's topic in Projects
    Ok. No laughing but i found the problem. The 5 bulbs that go in the binicle were in the wrong order. How stupid do i feel. Ok only i prob now. When i push the start button nothing happens. No movement no sound. Any ideas guys.
  14. pignapper replied to pignapper's topic in Projects
    Ok guys need help. Indicators flash correctly now but when i turn on left indicator the turn signal light on the binicle doesnt flash the nuetral indicator does. Also high beam light on binicle is constantly lit all be it very dim. Ill try and post a vid.
  15. pignapper replied to pignapper's topic in Projects
    Just looking at that stripe on the tank. Proper chuffed with that. Never used that bendy masking tape before. I might start doing this as a job. Lol
  16. pignapper replied to pignapper's topic in Projects
    Thanks
  17. pignapper replied to pignapper's topic in Projects
    Tried the battery to test electrics and pissed myself laughing. Opposite indicators flashing, no neutral light, no clock lights and nothing on the start button. Oh well wiring check needed.
  18. pignapper replied to pignapper's topic in Projects
    Tank ready for rub down and laquer.
  19. pignapper replied to pignapper's topic in Projects
    Engine in and tried it with tank placed on. Getting there.
  20. pignapper replied to pignapper's topic in Projects
    Engine going in
  21. pignapper replied to pignapper's topic in Projects
    Engine going in
  22. pignapper replied to pignapper's topic in Projects
    The thought that it would look good did cross my mind but not for me. its an idea for a future project though.
  23. pignapper replied to pignapper's topic in Projects
    Lol. Sorry that was me having trouble posting after a few single malts. kept younall guessing tho.
  24. pignapper replied to pignapper's topic in Projects
    So im getting there. Also have new exhaust in its box. Big push now as im off work for 2 weeks so ill update often. Stay safe
  25. pignapper replied to pignapper's topic in Projects
    Ok guys back after the crappy weather. As you will see over the next few pics things have moved on a little. Frame done and most of the spaying. Have now started the rebuild.
