Markudell660
  1. Thanks for help guys starting to find my around the site now, glad I found the club and joined. I will check in most days for a look around.
  2. Thanks for the advice guys, really good to have helpful people out there rather than relying on garage advice that always ends up costing money, thanks everyone.
  3. Hi, that's very helpful, I have just done a service so maybe I slightly over filled, it's hard to get right on this engine as no sight window and two sumps so you have to part fill start bike then turn off and put some more oil in, and when checking oil the manual says to start rev five times turn off then check oil level, a bit hit and miss idea I think. Mileage is 8300 so hopefully no engine wear problems yet surely, thanks for help.
  4. Hi I have a mt03 660, I quite often find a small amount of oil in the air filter housing, there is a drain pipe that comes out the bottom of the housing and comes put under the engine, it has a small plastic stopper in the end and when removed there is a small amount of engine oil that comes out, is this normal or a problem, any advice would be great. Thanks mark
  5. how do I leave message in workshop area I can't find it
  6. Hi everyone, I've got a 2009 mt03, I seem to get some oil ending up in the air filter box which can be drained out of the pipe coming out underneath, is this normal or does this mean there is a problem somewhere, would appreciate any advice. Thanks mark.
