Solid
  1. Hi Guys. There seems to be some confusion - my fault - about the size of the current jet, it was replaced during the top end rebuild. I will get in touch with the garage and find out its spec. Thank you for your help, I'll post again when I've got more accurate info.
  2. Hi Guys. Having real problems getting her to run properly. SYMPTOM: When riding in 5th at about 60mph, If I come off the power the bike wont start to accelerate again until the speed drops to about 35mph. (Feels like she's bogging down!) Does the same thing in 4th aswell. + Had full top end rebuild. (Ran fine after rebuild) + Carb float valve replaced + Jets flushed and cleaned + Tank cleaned out and flushed + Adjusted mixture screw several times - no luck + Running slightly smaller jet at the moment - could this be source of problem? Any help really appreciated.
