imcanadian
Everything posted by imcanadian
  1. Hers one for the books. I have a late 70's dt 175 where one minute it worked fine next it died. the ignition failed. checked all components from ignition to the points. Everything checked fine and still no spark . I'm not a mechanic but have enough years or experience with engines to solve my own engine problems by refering to a manual of some sort, but this one really stumps me. When the flywheel is seated properly on the crankshaft you get no spark, when you move it out away from the engine about 1/8" of an inch we get a nice healthy spark. Now a simple solution woul be to put a spacer behind the flywhee and solve the issue unfortunatly the shaft is tappered the flywheel would not sit securely in place and probably vibrate badly. I thought the flywheel maybe grounding on some component but clearance seem to be present. Has anyone encounterd a similar problem or have a solution?
