Everything posted by Chris125
Hi I'm chris
Thanks for the warm reception everyone
Dt125 lc mark 1
I understand I need to be systematic in my approach to finding the problem. Cleaned the carb out its set at standard on all fronts, I had the problem before I changed exhaust and air filter they were both changed due to them being in extremely bad state,(cracked, holed, split). And understand that I will have to rejet it due to this even though the problem hasn't got any worse No 2 stroke tank so have to premix, yes it uses water and will be doing a compression test when I can get my hands on one or the money to buy one
Dt125 lc mark 1
- Dt125 lc mark 1
Any noise I should be listening out for and how will rings appear if there worn ?- Dt125 lc mark 1
And could someone explain plug chop as I've never heard the term thanks- Dt125 lc mark 1
Thanks for the replys everyone Haven't done rejet on carb yet as had the problem before upgrade exhaust although if i remember correctly my plug was pitted with black carbon deposit so might need rejet do i go up or down? no noticeable leaks but will have a better luck tomorrow or over weekend , compression seems to be ok only done thumb over spark plug test and if its rings won't it smoke badly out the exhaust ? The rings have been in the back of my mind as i dont think they've ever been changed Should mention that I premix my two stoke, two caps to a full jerry can. Too much or too little thanks again for the help everyone- Hi I'm chris
Hi I'm chris and im addicted to any toys that take petrol i have a dt125 lc mk1 100cc blaney fx quad 6.5hp Murray go-kart and am currently working on my other half to get a wr250. I'm having some trouble with my bike I bought a dt125 mark1 lc about 18 months ago, it was in pretty bad shape cosmetically seemed to run ok albiet topend was poor and start first time on the kick. When I open her up it loses power to the point of being in top gear and dropping it to 3rd just to get it moving again. Thought it could be a exhaust problem as it was welded leaking and all the rest of it so went and bought a new big one exhaust, changed air filter box for k&n style filter and I'm still having problems from 3rd gear up with power loss anybody help is greatly appreciated- Dt125 lc mark 1
Thanks for the warm reception and the point in the right direction- Dt125 lc mark 1
I bought a mark1 lc about 18 months ago, it was in pretty bad shape cosmetically seemed to run ok albiet topend was poor and start first time on the kick. When I open her up it loses power to the point of being in top gear and dropping it to 3rd just to get it moving again. Thought it could be a exhaust problem as it was welded leaking and all the rest of it so went and bought a new big one exhaust, changed air filter box for k&n style filter and I'm still having problems from 3rd gear up with power loss anybody help - Dt125 lc mark 1
