boxer_ted
Everything posted by boxer_ted
  1. Original post: xt125r bogging running rich. Update on the fault. It turns out that the set up was not overfueling but quite the opposite. A fuel starvation scenario sent me down a different thought route. The carb was ripped out again and the main jet and emulsifier tube removed. The emulsifier tube housing/channel revealed a small hole, linked to the the air intake duct and on closer inspection with a strong lamp, was not letting light through. More dirt was suspected, so the orifice was subject to a squirt with carb cleaner and a small strand of strong wire. Light was eventually detected thus some crud removed. The carb was reassembled and reinstalled and hey presto the bike now runs OK. Just need to find the sweet spot on the air/mixture screw as I fiddled with this during the fault finding process. So in summary, when you clean a carb, spend some time to inspect thoroughly and ensure that every orifice is perfectly clean. If I had spotted this earlier it would have saved me a lot of unnecessary work.
  2. Sorry, just re-read post, you have already sussed this.
  3. Looks to me that the tang will shut the fuel off far too early. I have not seen one bent this severally before. The float bowl will have harldly any fuel in it.
  4. Hi all, Update on the fault. It turns out that the set up was not overfueling but quite the opposite. A fuel starvation scenario sent me down a different thought route. The carb was ripped out again and the main jet and emulsifier tube removed. The emulsifier tube housing/channel revealed a small hole, linked to the the air intake duct and on closer inspection with a strong lamp, was not letting light through. More dirt was suspected, so the orifice was subject to a squirt with carb cleaner and a small strand of strong wire. Light was eventually detected thus some crud removed. The carb was reassembled and reinstalled and hey presto the bike now runs OK. Just need to find the sweet spot on the air/mixture screw as I fiddled with this during the fault finding process. So in summary, when you clean a carb, spend some time to inspect thoroughly and ensure that every orifice is perfectly clean. If I had spotted this earlier it would have saved me a lot of unnecessary work.
  5. Thanks for link. Will bid on this item and let everyone know how this fault pans out.
  6. V/v timing checked and all OK. Have not yet tried a different carb, this is what I was thinking of doing next. Just got to find one now!
  7. Carb does not weep fuel from bowl so am assuming that the needle valve is shutting fuel off as required. The floats are bone dry and are moving with ease, the only thing I can't check is free movement when the outer case is re-assembled although I can here rattling if I shake the carb. If nothing else, this is a good fault........
  8. Hi, Spent two days on this so far and running out of ideas. Bike starts and seems to run OK until it starts to warm up. After this period the only way I can get it to rev up is by feathering the throttle, a faster throttle opening leads to bogging, a horrible response in terms of sound. The engine will also die if throttle is opened quickly. Checks so far include: Air filter, carb clean (several times), changed oil and flushed (x4) due to traces of water. Generator coils and spark circuit checked. Even had the head off to check timing, valves, tappets etc. This bike (2008 - 3k miles), seems to be over fuelling. When I take the carb off, there is petrol all over the inside of the inlet rubber. The choke mech' seems to be functioning OK also. The spark plug, unsurprisingly is sooty & black. I can't help but think that I am missing something with the carb (float/height checked) but they seem quite basic units compared to the Keihin on my Drz. All other pointers greatly received. THX
  9. Hi everyone! As a father to a teenage son that is now in his second year of biking, I would like to introduce the pair of us. He has just got rid of his Chinese plastic pig and recently bought an xt125r that is poorly - more of that later. To be fair to the pig, it got him to college everyday, a round trip of 25 miles and allowed him to carry out the so called "twat laps", I guess these are the constant loops around the local town to pose??? Glad I didn't do things like when I was young. I have owned and worked on bikes for many years now and let me cast my mind back to recall....... NSU quickly, FS1E, RD250, DT175, DT175MX, RD350 p/valve, GPZ 650, DR650, FMX650, DRZ400E, 883 Sportster, the latter three I still have. Just remembered, had a CD175 Benley in amongst that lot somewhere as well. I'll try and abide by the site etiquette but being an older model myself, tech' is starting to allude me. Apparently, you have to plug some cars/bikes into a computer to tune them, what's all that about? We once did this with a screwdriver, grinder and polish etc. Anyways, once again, hello!
