o5otato5o
Everything posted by o5otato5o
  1. think timeings out ? how do i adjust it
  2. right tappets set no change andrew can you get me a photo of your tdc marks lined up at all ?
  3. no wont idle i have to blip revs
  4. found it on here via a google Valve clearance inlet 0.05-0.09mm exhaust 0.15-0.19mm
  5. yes andrew now used tho lol think the soot is from when i put oil in the head as id been told previously but in tappets at min
  6. sorry for multi posts pretty desprate and just workin out how to use this forum
  7. plug after a ride home from work
  8. So the feelers ive got start at 0.05 any good? Next up is 0.10
  9. PS thanks for your support so far guys mucho appreci i will share some pictures at some point aswell
  10. ok lads will let you all know tomorrow thanks as i said m8 ive tried a freinds battery (off his dtr125) he uses daily and mines new plus had a full charge last night its shure not the battery deffo some sort of fuel/air issue i think if not i hold my hands up (useless)
  11. ebay or local dealers
  12. only thing i changed was tappets and used a rizla packet top tab lol is it the actual papers ypur supposed to use ? loaned my feeler out and they never came home ps tried a freinds battery (he still useing daily) mines 2 month old if that so i know its not battery
  13. why isnt there a check list order lol sooo hard picking up my feeler gauges tonight if push comes to shove its my first time takeing a bike to a garage been 9 year lol (allways had 2 strokes tho) i will try tho i am determined but yes going full check list again one last time will allso add piks as i go this time so give me a few days guys as got to fit it around work Just check tappets are .004 and .006 ? i always thought .002 and .006?
  14. ye ive done the oil in head and leave plug out aswell the oil in head caused slight smoke and after a few attempts it fired (seen that in one of you other posts) but still no go over all i.e. it just died on tick over
  15. i have tried then all every suggestion has made no diffrence im afraid apart from trying to fire with tank open will try now got a break didnt work
  16. it can fire but its asif i cant sustain its self under running pressure it will get to the point of wanting to fire but just doesnt have that little bit extra
  17. yes tried that aswell andrew
  18. was not sarcastic sorry if it sounded that way my grammer sucks never thought to try with fuel tank open but put a full tank of clean fresh fuel in today as i thought mabe a dud batch as it happens some times. fuel flow is fine tried that. the jump from a car is my next test but at work while 8:30 all week
  19. started when i came to work friday left friday to go home wouldnt start just turned engine over it tries to fire but wont go that little extra to fire so i thought first cheapest thing buy a new plug new plug in and still the same so asked the guy at the shop he helped me bump it and said seems low on compresion so to set tappets so did that and still no luck so cleaned carb still same i thought at that point mabe a blocked oil filter or crappy oil so replaced them and did oil change still nothing
  20. slightly obviously to bump it
  21. really awkward with tools i have thats your mix andrew mines set to 1.5 out carb has to come off lol its really starting to seem like a compresion issue but cant seem to find where not rings no smoke at all from her
  22. ye andrew thats as we call it in uk ur tickover/idle screw and adjusted it full same at handlebars/rev
  23. not just yet noise would doing that tell me anything? short of stripping top end down think i tried everything?
  24. No fuel pump yes fuel is gettin there as ive said she tries to go off button.but just hasnt got that little extra umph exhaust and head both get warm
