drkdemon176
  1. is it ok to set it fully open??? my mate set his to open and wow it was very fast the when it kicked in , but it also got very hot at the same time , just don't want to damage the engine thanks
  2. no wires or nothing I am taking it its just set to one position and that's it feels fine though the gears and everything just not getting the kick if u know what I mean
  3. ok thanks and no wires that I can see gaz
  4. thanks blackhat250 yes I think I understand that just unsure where to set it or do I put a servo on because not seen another dt with the manual bit thanks for your replay gaz
  5. Hi slice I do tbh... but it doesent say anything about manual pvs the servo might of been taken at some point I am unsure all I know is it's not kicking in , I was told to set it to open full but don't know if that's a good idea tbh.. I don't honestly know .. thanks for your replay gaz
  6. hi all had this dt a few months now and everything seems to be sweet apart from the manual power valve system doesent seem like the power value is kicking in maybe set to closed I don't know what is the best way to set these sort of power valve systems or should I buy a servo for it I am un-sure tbh.... don't know what to do or could I set it fully open or will this cause damage to the engine ????? any help would would be much appreciated many thanks gaz
  7. hi all thanks for having me Ned a little bit of help with my Yamaha dtr 125 it is the model with the manual power valve now I have had a little mess with it I set to to fully open I think and closed had plenty of power when it was open but no power bottom end. what do u recommend servo or is there something else I can do ? thanks gaz
