DtMitch
Everything posted by DtMitch
  1. hi guys, my friend has just recently bought an 03 model dt and were both a bit confused with getting it to run properly. the day he got it he rode 25miles home, once home he realised the boost bottle on the side of the airbox wasnt even connected. after reconnecting it i cant get it to idle well, the mixture screw is all the way in and it kind of idles but every now and again the revs build up to around 5k and stay there until you blip the throttle again. the main jet is 240 and i now stock is 210, it has a dep pipe but is it possible for the jet to be too big? i can get it to run and idle fine with the choke on but cant do anything with it off. i recommended that he should buy 210, 220, and 230 main jets but im not sure tbh.
  2. ooohh.well its back together now and sounds exactly the same
  3. ok so top of piston measures 56.40mm and the bore measures 56.98 is this right or does it seem too small?
  4. ok.so ive stripped the top.end down and cant really find anything wrong with the little bearing so it must be the piston and bore. im replacing the bearing anyway and ill let you know how it goes. a create a problem for myselft tho, trying to be clever i thought i could remove the whole top.end as one, and forgot to drain the coolant. so now my crankcase has coolant in it
  5. ok ive just ordered a new bearing and gaskets which will hopefully be here tomorrow, if so ill strip the top end down on saturday and ill post my findings on here. i just really want the rattling gone as im selling in a couple months and it really lets the bike down
  6. hi there guys im wondering if anyone could give me any advice on what to do my bike has an annoying rattling noise which seems to be coming from the top end. it had a +1.0mm rebore just under a year ago by a previous owner and was fitted with a wossner piston, which has always slapped from cold. i have taken the head off and attempted to measure the bore and got 56.97mm as my biggest reading but im guessing it is 57mm, bore looks nice and clean. but i had no feeler gauges to hand at the time. bike starts first kick every time without fail and pulls well through all gears anyway back to the noise. on start up the piston slaps is the prominent noise from the engine, however there is a rattle which seems seperate.to the slapping in the background. the rattle is there at tickover, not so much on acceleration but very distinctive on de-acceleration however is seems seperate from the engine speed. its really annoying and difficult to explain. Any advice would be appreciated, thanks
  7. it most likely is compression related, if you dont have a compression tester take the spark plug out and cover the hole with your finger and kick it over, you shouldnt really be able to keep your finger on the hole but obviously this is far from accurate
  8. i dont know if anyone will read this again but i just want to correct myself to maybe help others in the future. anyway, my chain was quite loose so i went to tighten it today and found the left adjuster to be on 5 and the right on 6
  9. hi again, i changed the gearbox oil and went on a long ride and it seems to have resolved itself. thanks a lot for the advice and if the problem persist then i know who to ask
  10. its just as its running aswell, when its stationary it goes from 1st to 2nd nicely, i really dont know where this screw spring and ball it tho, and i dont know how to upload pics
  11. morning guys, im out working on the bike now and have just removed loads of mud from the front sprocket area, but it didnt seem to make a difference. the engine plug on the left side is very tight and i cant see any screw around the clutch arm so im a bit confused tbh
  12. oh yh another thing it does is that sometimes if can feel delayed between the shif and actual gear change. kind of like its sticking
  13. thanks for the replies, yh it has gearbox oil but i am gonna change it tomorrow anyway. also if that ball is the problem then what is the solution? will i need a new ball or spring?
  14. hi guys i have a problem with my dt changing from 1st to 2nd. it started yesterday after using the bike for some enduro riding, i rode from 10am to 3:30pm with regular cool down breaks. i will say that most of the time i was in first gear with fairly high revs. well now the bike goes into first easily but then struggles into 2nd and is then fine throughout all the gears. is it possible to damage a gearbox from riding in 1st for a long time? any advice will be appreciated
  15. Nevermind ive just had a look online and yes they use studs which i can get for about a tenner for the pair. Its just getting the thread back which is the annoying part, im very hands on with my bike and like doing as much as i can myself. However maybe its smarter to leave this for someone whos done it before, last thing i want is to completly ruin it lol
  16. Yh thats what i thought
  17. Hi guys thanks for opening my thread Im in need of a bit of advice, ive had my bike for a few months now but have never noticed the exhaust bolts being loose till today. The right one tightened down fine but the left one was stripped so just kept turning, the bolt is also slightly longet than the right one. I just wanted to know what you guys recommend, i was gonna try tapping it out to the next size and finding a bolt to fit. But reading some threads online people have mentioned having studs instead of bolts so im not sure which is right, mines a 2007 model. Anyway guys i appreciate any advice and thanks for reading, if nobody advises otherwise then ill go ahead with tapping it tomorrow
  18. Ok haha thanks (i think) for the reply. I guess ill just have to try and figure it outbon my own
  19. Hi guys ive only had my dt for about 3 week and today i got my first chance to open the throttle up properly and i was quite dissapointed by the 65 mph top speed. The owner before me said he has earthed the cable behind the headlight so i checked today and he has snipped and extended the cable and it goes off underneath the ignition plastic cover thing. Its got carbon reeds, a 900 miles old top end with 1mm oversize wiesco piston and pulls very well upto 65mph but then seems to just stop, it doesnt feel like im even ragging the hell put of it. Bearing in mind nearly everyone says they can get 80mph out of it, then you can see why im dissapointed. Has anyone got any ideas or advice for me? Reading online i found one sight saying to block off the plastic boost bottle thing but i doubt that will do much
  20. Haha well from what ive just read online its normal for wossner pistons to slap when cold. The engine pulls very well and i cant see that it would sieze doing a wheelie (on private roads of course
  21. Calm down, im just giving my opinon
  22. Hi guys, just got a couple of questions about my bike. The top end is apparently 700 miles old and pulls very strongly, but uses a wossner forged piston and slaps when cold until warmed. How long shall i leave it to warm up before riding? Also, after a 700 mile old rebuild would you guys say its ok to be doing/attempting wheelies, after warming up of course?
  23. I would also say its either clutch related of the gearbox internals. Does the bike ever wanna pull away even with the clutch in? If so its dragging, i believe.
  24. Sorry guys done my intro for y'all
  25. Sorry nevermind my first post is already here, thought it had been deleted haha im all over the place on this forum
