VinXCz
  1. I Guess , i am not sure of it..!!
  2. Normal push is restricted, but more push will overcome it, the restriction and overcoming of it happens in cycles. When bike is started it performs normal, it doesn't creep forwards with clutch held in.
  3. Guys thanks for the information, but the bike is not started, not holding the clutch lever, not in neutral, but till the bike has some restricted movement.
  4. Hi Guys, when i push my bike a little bit harder when in gear (without holding down the clutch), it is moving forward. Is this common or i need to check anything...??!!
  5. Thanks guys, this has helped a lot, I'm able to start the bike now ...one more help needed though, when the bike is in neutral, the accelerator response is very good, but when changed to first or second gear the response is quite bad at lower rpm, higher rpm is again good. Any suggestions on this...!!
  6. anyway, i have replaced my spark plug with Iridium NGK, no luck couldn't start the engine, also can you tell me if iridium spark plug draws more charge from the battery..?
  7. i am not able to see any spark, just wanted to know will the spark be clearly visible in sunlight or is it very minute?
  8. Mine is a carb type. 5 year old now. I have opened the fuel pipe and checked, the fuel flow is normal. no blockage. now there s one more issue that's come up. I have replaced my old battery because it was almost 4 year old. When i try to start the engine, it just gives cranking noise continuously but doesn't start. Full fuel, full battery but no use. Any clues where to start.?
  9. Okie, thanks for this info, i will be checking on this now, i would also like to know more about the engine check light, like what all checks does it do.
  10. I own a Yamaha FZS bike, now four years old. I'm experiencing problems during revving up the bike to high speeds. The engine gives up suddenly, the throttle doesn't respond(like what you face when the fuel tank goes dry), but the fuel tank is full, battery is recently charged. Then I need to keep the bike idle for around 10 - 15 minutes, then the engine check light blinks and then i can start the bike again but not for long when this happens again. I have changed the whole electrical wiring twice now but doesn't seem to solve the problem. It works good till a week after servicing the bike, but then this starts again. Please guys help me out to fix this.
  11. HI Guys, Need some of your views on what might be the problem for my bike. I own a Yamaha Fazer bike, now four years old. I'm experiencing problems during revving up the bike to high speeds. The engine gives up suddenly, the throttle doesn't respond(like what you face when the fuel tank goes dry), but the fuel tank is full, battery is recently charged. Then I need to keep the bike idle for around 10 - 15 minutes, then the engine check light blinks and then i can start the bike again but not for long when this happens again. I have changed the whole electrical wiring twice now but doesn't seem to solve the problem. It works good till a week after servicing the bike, but then this starts again. Please guys help me out to fix this.
