dnikoloutso
  1. Hello guys, I have a yamaha diversion 1992 and I want to put new tires on. Do you have any recommendations on brand or type?? thanks! Front tyre dimensions: 110/80-17 Rear tyre dimensions: 130/70-18
  2. Hello, I just bought a yamaha diversion xj600 1992. I have the following problem. at low rpm (2-3-4000rpm), the engine power has some fluctuations.it has 24000 miles. I went to a mechanic and he told me that all the cylinders are working. to better explain it is like the engine is coughing under 4000rpm. even with a steady throttle you can feel that the power is not equally distributed. the mechanic told me that I might have to tune the carbs. Any advice? thanks
  3. it has 24000 miles. I went to a mechanic and he told me that all the cylinders are working, so now i m left with this power fluctuations problem. to better explain it is like the engine is coughing under 4000rpm. even with a steady throttle you can feel that the power is not equally distributed. the mechanic told me that I might have to tune the carbs. Should I do the compression test? I ll also post in the newbie section. i guess this is what you meant by neebe thanks
  4. Hello, I just bought a yamaha diversion xj600 1992. I have the following problem (or not!). There is a slight kicking sound when I start the engine. I googled that and I found that two cylinders might not work. Also, and that might be related, at low rpm (2-3000), the engine power has some fluctuations... Other than that it runs well. How can I find out if there is indeed a problem? how bad is to ride it like that? and is that a hard and expensive thing to fix? Thank you
