alfotuning
Everything posted by alfotuning
  1. Yes I believe b&q sell so I got told a min ago ill post some pics when ive made my wheelie bar thanks
  2. I need some square metal tubing but not sure where to buy it from does anybody know if jewsons or b&q do metal I looked on there website they do building stuff but not sure abut square metal tubing or a flat sheet metal don't need alot to make a wheelie bar
  3. Thanks for the reply. Ive never took my reeds out so I'm not sure what the look like. If they stay cheap maybe ill buy them in not sure.
  4. i have never took my reeds out people say they need replacing and very important to look after them but i cant believe it makes much difference using vforce?? any way they look same on google as the dt125 reeds will they fit thanks http://www.ebay.co.uk/itm/V-Force-Reeds-Husqvarna-125-/171468190398?pt=UK_Motorcycle_Parts&hash=item27ec4cf2be
  5. its in bits piston looks like new so does bore although a bit of water in there. i took head of and over tightened thermosta bolts and now wont do up. oops. so its in bits now untill Athena kits get on. also looking at spark plug its a light brown its jetting to big 230 jet thanks
  6. but what makes a head gasket leak? i do rag the shit outta it ?
  7. its done 4000 miles with leak another week ill have 170 kit so all be changed so doesn't matter
  8. The cap looks fine :-\
  9. Its genuine !!!! Head gaskets all other are Athena but head is genuine !
  10. Okay so bike keep lossing water radiator gets empty light comes on but after looking all i see is the overflow pipe for expansion bottle on back of bike when riding losses loads of water ? The overflow pipes so long it goes from expansion bottle to front off bike around engine and back up i put it up high so i could see it it deffo lossing water from there but why?? Confused Need help
  11. what jets should i buy 240 250 ..260.
  12. ill probably order it then have a radiator leak always seem to drop water somewhere :-\ also need a new air box bit the rubber what is under seat for air box i cut it and sound different lol probably slower now seem to bog when first rev from idle but can't find a new rubber bit hmm
  13. it sounds lush its £420 for Athena 170cc kit but people say Athena kit is shit! i dont want to waste money :-\
  14. My dt is nothing like this i dont understand how he wheelies so easy like? would a 170 Athena kit make it more like this?
  15. thanks for help. just was thinking 170 Athena kit but i would rather buy a wr 125 x but £2000 max spending money although all to expensive :-( my dt is worth about 1700 its really clean polish it every week lol.
  16. Yeah i understand I've got full dep! stranded carb everyone says 32mm carb but then i have to fit apower filter and normal air box has to be took of meaning no water trap for.air filter ? so bike probably won't run in rain? is there a carb that will fit on air box manifold rubber to air box and run good? also i understand just thought bigger piston needs more oil but that's good oil pump works fine nice and smoky when cold
  17. so you say changing jetting on standard carb will work ? also what about the pre mix oil system leave it or does it need more oil ? Thanks for the reply ( Y) and spark plug color should be like what? Also how do you set it up when running in engine like just rev lightly? thank you.
  18. hi all recently done a top end rebuild on my dt std piston runs fine only done 3,000 miles but Im thinking of putting a 170cc kit on :-) for more power i always see people on YouTube poping wheelis in 3ed although mine won't. a 170cc Is around £400 for cylinder piston rings ... i understand how it all bolts together. What Im confused about is changing carb and jets to run corectly obviously i dont want to fit all new piston and blow it up or damage it. also will it need to have the oil pump changed with a 170kit will it need more 2 stroke oil? if i can't use std carb because i won't run correctly what carb will.fit ? Any help would be very helpful. even more helpful if your running a 170cc kit in your dt.could you tell me what its like? than you
