Posts
743 -
Joined
Last visited
Days Won
25
Content Type
Profiles
Gallery
Yamaha Racing News.
Media Demo
Store
Collections
Classifieds
Everything posted by KevtheRev
I'd be more worried about that baldy back tyre .
Whip the cover off and have a look , there are small cutaways in the clutch plain plates to reduce clutch noise . They may be mis-aligned , if not, check the basket and centre for notching . If the original cluthplates are in the bike they may have stuck together over time . They're easily replaced .
Hold on , before you do anything , check the condition of your fuel petcock at the tank to make sure it's not leaking and check the carb floats / float needle and seat as if any of these arent working it will allow fuel to reach the engine while the bike's not running .
You never mentioned a bigger piston , and I mentioned sand as you said you lived on the beach . I've seen new piston rings break because the bore wasn't honed properly after a re-bore . That'll cause backfiring and sticking too , usually accompanied by rattling and vibration . As for an electrical problem , what's your battery like ? If the reg/rec is fooked the battery won't charge and could affect running if it goes flat ., or a broken or shorting wire to the HT coil or points/CDI unit/ignition . Is your stator plate aligned properly (did you mark it's position before removal ?) . A bigger piston doesn't necessarily mean you need to increase the main jet size . Is the spark plug wet and/or sooty as a sticking choke or rich fuelling can also cause the symptoms you describe .
P.p.s. You don't have sand in the float bowl do you ?
P.s. Your best bet is to get a workshop manual (Haynes are good ) and get your carb back to standard settings . That'll be one off the list and a good starting point .
P.s. Your best bet is to get an workshop manual for a few bucks and make sure you've the carb back to standard setting , that'll be one off the list .
You wouldn't be a tooth out on the cam or anything like that would you ? Don't overtighten the exhaust bolts , better to get as new copper ring seal as they are only a few cents . Was the bike running well before , and did you replace the camchain ? I can't tell if you've done many miles after the rebuild but I'd check the top end for oil starvation esp if any rubbery instant gasket goo has been used . Don't panic , it could be a small electrical or fuelling problem and you'll just need to eliminate the suspects one by one in a methodical fashion . Best I can say on the info you gave . Fair dues for giving it a bash .
No as long as it's not kinked or pinched anywhere it should be okay . Always double check before going out on the road tho' .
Hi there Adam . A few well placed cable ties will tidy that up for you . I'd pull most of the slack up toward the top , kinda like a motocrosser . You can loosen the top banjo bolt to change the angle of the brakeline if needs be , but you'll have to bleed the brake after . You don't want that bowed out bit in the pic catching on someones tow hitch .
They'll be alright , lol . You wouldn't happen to have a tank and a crank (or any other bits ) for an ageing old lady who's been round the track a few times , but would like to kick up her skirts for a while yet , would you ?
Just don't forget , old bikes ran on points ignition , new bikes don't . Nothing wrong with points by the way .
The HT coil would be the least of your worries as most will run at 6 or 12 v but the ECU and any other sensitive components may not . PS I'm no electrician but I'm sure anyone with more knowledge will tell you the same . I often had the same idea as you when using a 6v bike , crap lights etc but I think it's more trouble than it's worth . Unless of course you know an auto sparks who knows better than me .
You'll have to change your reg/rec , relays and bulbs . Will the generator handle a 12v battery ? I'd leave well enough alone buddy . There are nice digital speedos for bicycles which work well and need no connection to the bike's battery .
Just remember , until you know different , everybody else on the road is deaf , blind and stupid . Even if an accident is someone else's fault the motorcyclist is usually the one to come off worst so assume nothing and take nothing for granted . Motorcycling thrusts personal responsibility on you like nothing else . Who says bikers are irresponsible ? Not from where I'm sitting !
My bike however is an Irish reg'd bike .... And you wouldn't half know it ! Everything breakable has been broken/discarded and everything else finished in a nice farmyard Red Lead and tastefully contrasting JCB Yellow !!!!
The bike was actually a German import and whoever put it together knew what they were doing , it had a serious tune . Bro' blew it up flat out on the back roads one day and it lay in a box for years . The colour was battleship grey but Bro' changed it to the fetching R1/Candy Blue with metal flake we see today .
One o' those "Coulda been worse " situations . Drove as a despatcher for 20yrs before that without a penalty point .
You can still get all the mechanical stuff for 'em pretty easily , if a little expensively . I've one in the garage needs a crank and a tank . I won't be getting it as pretty as bro's but I'll make a useful bike out of it . I been off the road since I picked up a 4yr ban about 6yrs ago and I can't wait to get the bike running . Funds , as always are the limiting factor . I've a nice set of Allspeed stainless pipes from an air cooled 400 that were on bro's bike so I know they'll work well . Gonna put a race seat unit on and a digital speedo . I'll post up some pics of the neglected old girl soon .
Uh oh ! Those bubbles can be impossible to get rid of . Luckily it'll do no harm . If it was a bubble in the two stroke delivery pipe(s) , that would be a different thing altogether . Always use clear 2stroke delivery pipes so you can keep an eye on it . I'd follw Airhead's suggestion and get a black fuel line , that should get rid of 'em for you .
LC fuel tank - more holes than a dartboard .
KevtheRev replied to KevtheRev's topic in Yamaha Workshop
Cheers Slice , I'll keep that in mind . -
Yeah , nice isn't it . Only took him 10yrs , lol .
