Everything posted by KevtheRev
Jog help needed!
Sounds like it needs a service . It takes about an hour to service the thing but learning how to do it in an hour takes years lol. Welcome to the forum . Try charging the battery and a new spark plug , maybe someone you know could give you a hand ?
Engine bolts
Dunno Mace , you'd have to check part No's or have 'em side by side .
- Route through London?
Primary Carb leaks fuel after shut down
A good cleaning might do the job . I've heard those ultrasonic cleaners are good for carbs . If your not too sure wait until you give the manual a good read . Best o' luck .
hey all
Fair play , happy biking !
ybr custom 125
Hi Tia , should be a simple enough job . Have you googled for any particular ones ?
- Where did all those years go
Yam air cooled 4 cylinder
We are a broad church here Vario my son , and can respect all of Gods creations .
Fitting Custom Fender to Virago 535
As Slice says , "As long as it doesn't foul anywhere" , It's a mudguard . A slimmed down guard with a fender extender would be nice . The one on my bike is off a mountain bike rear mudguard . I found it , lol! It's on the front , rightly keeps the crap off too . Fame at last ! lol , I've seen some nice mudguards made from old tyres ,
About to Buy My First Raider. 3 Bikes, which would you choose. HELP!
Hey , congratulations Kiwi , make sure you rack up plenty o' miles now .
Finally back on the road
Hi Grouch , I stuck a video up for you in the vid section ,
This one's for Grouch -
- Racing Holiday ??
It doesn't always rain , just most of the time , lol .- [HELP] -TZR50 Problems
Sounds like crank seals to me Milan , but very little info so just a guess really .- Problems- Yamaha TZR50 '03
Sounds like it's banjaxed !! Probably crank seals .- Racing Holiday ??
Hi lads , I've noticed a lot of you oldfarts are retired , why don't you get over to Ireland for a spot of rest and relaxation this Summer . Much easier to get somewhere to stay than at the IOM and and cheaper for you Brits with the Sterling rate , always somewhere to camp ,and an awesome racing experience with the bikes within touching distance . I guarantee you'll be back , lol .- Motorcycle Raid
I saw a vid very similar to that , think it was from Thailand . One of the tealeaves got shot in the spine and wound up paralyzed on his knees . There it is ! That'll be the last bike he tries to nick .- Those nice folks at Yamaha.
Awesome ! They don't fanny about when they're building jetskis either .- Yam air cooled 4 cylinder
I think they had a kickstart as well ! When men were men eh ?!- Hi, new on here. Just want to share with you.
Someone trying to cod us ?- DT175north
Hi there , best of luck with the bike . Plenty of experience to draw from on here pal .- Hey, I'm Justin!
Welcome aboard ! Bikes are much easier to deal with than cars . I mean for starters you've only got two wheels to worry about instead of four !- Hello. I'm new here.
I was a big Schwantz fan back in the day , so I didn't want to nick his Revvin' Kevin monicker , lol . Welcome aboard !- DT 175 erratic Idle
Hi Steve , the Prime position should flow freely , whereas the on/res positions need a vacuum , usually from the inlet stub , to work . My first guess at your running problems would be an air leak somewhere between the airbox and the cylinder head, so check the sealing at airbox , carb and for cracks in the inlet stub . But before you do that pop into the new member section and say HI , you'll get more answers that way . Best of luck !- [HELP] -TZR50 Problems
Check for leaking floats and examine the float needle and seat for wear . Also check the fuel switch on the tank and make sure that it is not leaking . - Racing Holiday ??
