KevtheRev
Everything posted by KevtheRev
  1. Rule out the simple things first eh' ? If she's low on oil check the camshafts for blueing . Hopefully It will be something small though . Good luck . Btw , 4 strokes can be more complicated and expensive to rebuild , unfortunately .
  2. Lovely stuff ! Best o' luck with her man .
  3. KevtheRev replied to Jack R1's topic in Projects
    Hi Jack ! (Shit hope the Feds dont read this ,lol) How's the lovely bike coming along man ?
  4. KevtheRev replied to Noise's topic in Projects
    Fair playbuddy . Nice bike .
  5. Just noticed this thread Finners . You're off to a good start . Can't beat a good DT for fun ! What's the crack with the motor ?
  6. Well done Ike ! I would try and get new Diaphragms though . Fair play to you !
  7. Did you replace the starter motor brushes Noise ? Did mine on the CG recently and I reckon the starter is putting out more power than the bike motor , lol .
  8. You could have , but I doubt it would run at all . Check the electrical stuff is ok .
  9. Did you check it for oil ??
  10. Best of luck with it Chris !!
  11. Why would anyone do that to an LC ??
  12. Put a new spark plug in and clean the exhaust out with caustic soda ( and be feckin' careful with that stuff) .
  13. KevtheRev replied to drewpy's topic in The Bar
    I hope you lads have a great time !
  14. KevtheRev replied to anyoldiron's topic in Classics
    Lovely bike !
  15. KevtheRev replied to Mr Bignel's topic in Projects
    They look fine , you could set them off nicely with some handlebar muffs .
  16. Is it still legal to tape over the offending part of the headlight lens ? Bro's LC has it done , no mot for bikes over here .
  17. That'll keep you rolling while you decide how to sort it . Do you know anyone who could drill it out for you and clean up the thread after ? That'd be my next step Grouch , although one of the others will probably be along with a better solution for your problem . Keep us posted .
  18. Have you ridden the WR250 ? If it's the 2 stroke version you might be surprised as to how fast they are . As for the tank range issue , Acerbis or somebody will make a larger one I'm sure .
  19. Just looked at the photo Grouch , I'd try Drewpy's approach , but use a blunt ended drift on one of those square projections at the outer edge . Best o' luck .
  20. You dont have to whang the crap out of it , one smart tap usually does the job .
  21. I've a set of large can Allspeeds on standby for my LC build . They're from an aircooled RD but the 'Bro had 'em on his LC and they looked and sounded the message .
  22. Result ! Lovely skills and a great looking bike . Well done man !
  23. If the mole grips fail , saw a slot in the head of the bolt and use an impact screwdriver to crack it off . Very handy tool for about ten quid . You can lay the bike on it's side on a couple of car tyres to make the bolt easier to get at . Best of luck .
  24. Hi there , make sure any circlips etc have been removed and use something with a blunt rounded edge , like a tyre lever to lever out the seal carefully , so you don't damage the fork leg . Stand the fork upright with the seal upward , place the lever under the edge of the seal , place a folded rag on top of the fork leg and push the end of the lever downward to push the seal up and out . Best of luck .
